The search is on..........
kieren1234
I want to buy an old mini but have no idea what to look for. I took SteveSpedd on the forum to pick his up today and it is an absolute stunner. Im sure he will post about it soon.
I ideally dont want to spend over £500 and would like one as tidy as possible (Steve spend £800 and its a minter).
Anyone know of any for sale and what i need to look out for also??
Any help appreciated (as long as it is related to my search for the mini, no sarcastic comments please :D:D)
Thanks.
hi mate ... good choice i have an ex drag mini aswell as the supe(ex because i melted the pistons :() i have an uber knowledge:sly::D of there mechanics and i am local (ish) to you so if you need a hand when searching ;)
i would recomend 84-87 (iirc) because this is when it was most revised mechanicaly before rover, rover used bad quality metals not resulting in bad mini's but it made the rusting worse (if thats possible:blink:) an average 86 mini will have loads less rust than a 1994+ mini;)
but on the other hand spi/mpi (fuel injected mini's) are good mini's mechanicaly (still the rover body tho) no where near as tuneable about 100bhp max on stock fueling.
if you get a totaly standard mini (doubt it) there are very simple mods: manifold, filter bits and bobs like that known as a stage 1 this brings about 20%hp gains (proven) over standard and these are bellow the £150 mark
parts as you say are easy and cheap to work with but the body work need doing its going in to the hundreds ££££ (if they look as if need a bit, they will need alot more:rolleyes:))
any way i must stop waffling because i could talk about em all day:d
p.s if ur looking for shows my faves :
*drag wars mini vs beetle, about easter(york usualy)
*MITP (the biggest) usaly 3rd sunday august(allover but mainly oxfordshire at the pod last year hense the melted-nes of mine :()
*drag wars may 4/5 ish sunday closest usualy, this is where all the biggies go and all the most powerful a seriesed ,mini's go Awsome!! :eyebrows:
anyways:)
btw at £800 your mate got a rite bargan :)
Thanks for the info. I have always wanted one and just want one now for a little run around, cheap insurance, tax, fuel etc etc.
I will check out auto trader and ebay and hope i can get one.
I have a good friend that works in car bodywork and paint spraying so the body could be sorted very cheaply.
just thought, when on a test drive you wanna be on the gas then break and gas again, in say 2nd gear if it pulls you around from the rear walk away ;)
at best it could be a well rusted rear subby at worst the subby could be no-longer mounted:Pling:,
*if its all over the road from the front it will be the ball joints not big job,
*if it pull to one side breaks (front)
*and wiggle the stearing wheel when your not moving not violently, there should not be any loud creaks and not loads of body flex(there will be a slight amount) or the front subby mounts are on there way out/or gone:)
and DONT use sinthetic oil:d if u still want a gear box:eyebrows:
get your self down to local wh smiths and but a mini mag/ or mini world that will be the best place to look as it will (more likely) have been looked after
good look pal:cool:
I just want an old banger for the £500. Im sure my friend can sort it out body work wise so as long as it is mechanically ok then thats fine with me.Anyone know of any for sale???
Yeh my old one is in my sisters back garden on its side... I decided to knock the back of her garage through and freeroll it into the back garden :D (down a big ledge) Then we decided it would be a better ornament on its side, so tipped it up!
She keeps nagging me to go round with an angle grinder and chop it into bits... poor old mini :(
