VERY Pissed Off
SupraD06
  • Replies 75
Even Phoenix only charge £35 an hour and there is no VAT to pay on that
£35 is uncommonly cheap mate, it's £45ph + vat round this way for the backstreet garages fixing mondeos, £65ph for performance cars and £90ph upwards for main dealers.
But I'm afraid £3.5k for BPU is a total and utter rip off, no two ways about it !
IIRC when I had a go on their rolling road he tried to convince me that I needed a boost controller and to remove the restrictor ring as the controller would limit the boost. Didn't matter how much I tried to convince him that a boost controller could only raise the boost, he was having none of it.
:faint:
any clues as to what 412fwhp is in bhp???
When they gave you the dyno results they should have provided them with a RWHP figure (which is what the rolling road actualy calculates), sounds like they didn't :(
Is it an auto or 6spd? With a 6spd, based on previous results it's probably around the 350rwhp figure, if an auto, probably around 320rwhp.
I assume that it wouldn't be worth involving anything like trading standards? On the grounds of selling/fitting items as "required" when they aren't?
dont kow mate, at the time he said "ill only fit this if i need to as i dont want to sell you things you dont need" where as what he should of said was " you dont need this and im ripping you off with everything im doing and your money is funding my own car, cheers mate"
I just want the place to get leveled
Hmm, I refuse to pay more than £40 per hour for labour, pretty much every garage (apart from Phoenix) have trained monkeys doing the work. If they were a real specialist, doing work that requires specialist skills then I would obviously pay for this. For spanner work, not a penny more than £40 per hour. That's more than I earn so may as well take the afternoon off and do it myself :D :p
when you say " though not impressive" do you mean not impressive because its only at bpu or because its not impressive for the mods ive had done???? either way like i said its about 2k down the pan wooooo hoooo may aswell laugh or else ill just cry:(
I meant thats it's okay for BPU, but not what you'd expect from a car with a mapped piggyback ECU. Mine made 430fwhp in the hot summer weather when running 1.15 bar with a stock ECU. If a piggyback ECU is fitted it can be made to reduce fueling at the high end and thus provide a little more power.
As mentioned, it's the Rear Wheel HP figure that really counts (along with a run at a reliable rolling road).
Not a good day today, anyone want to buy a 6speed tt thats had more money spent on it than can be accounted for lol
Mate,
As Homer and Matt says you've been ripped off bad... Another Supra Member on here as been to them for Suspension work etc..Ill ask her what sort of price they charged her..
Bit shocked they would charge that to be honest.. But then again i'm not shocked at anything now mate..
I live around 2 miles from these guys so if i can help in anyway.. I don't mind having a word with them on your behalf mate...
If i can help i will :)
Mate,
very good of you that mate, thanks very much, like i said in previous posts the price difference in the boost controller and turbo timer compared to most other places is just unjustifiable, with the high labour cost and things like the neo which i didnt need im seriously out of pocket and i seriously hope no one else even drives near the place. thanks again mate
No probs mate... Im frankly appauled about it... Like i said let me know if i can help
ive just been working it out and i reckon im £1283 over priced or there abouts, not sure there is much i can do about it now seen as it was nearly 8 months ago, just very dissapointed in them, they seemed very geniune, i did think he may even be a member on here as he has a 800+bhp supra as the demo car in the reception area which he owns, i think everyone needs to know about this kind of behaviour before it happens again
i thought standard 440s would be running at near enough 100% duty at that kind of power? not reccomended really is it? or am i off in saying that??
Some common misinformation there... though they are near (or at) 100% duty at WOT at 1.3 bar, the AFR'a and EGT's consistantly indicate overfuel at higher rpm. The only lean spot is the transition point. At the lower boost levels this will help the 2nd turbo spool quicker, but 440's are not an issue at high RPM provided the rest of the system is working 100%.
one more question, would adding 550cc injectors to bpu jspec make any difference, stock ems, or would u have to get emanage or the likes to benefit?
You'll be able to remove that very slight lean point at mid rpm, but it will make no difference to max power.
Some say that a little lean during boost build is a good thing and helps quick spool, so in some points of view leaving it as stock will provide max hp on the stock ECU
the garage that did it was WESTON PERFORMANCE in solihull
Took my car there a little while ago as i live 5 miles away, they couldnt find any faults and even though i was told i would get the diagnostics done for free i got a bill for £175,, i wont be going back there again !!
Doubt they'll stay in business for long if they keep taking the p like this.
