supra v8 project...
rxv8
  • Replies 230
Posted Images
  • 4 weeks later...
some more progress,just collected my new keisler t56 6 speed box,its been modified with steel shifters and input shaft,carbon pads etc etc,and viper gear shift/change linkage,which basically means its good for 700 whp...more than i need for sure...hopefully have the engine/box and prop fitted in next 2 weeks,then can get the exhaust made,i am going to use the borla xr-1, 4" in and 4"out back box which i have just receved from jegs in usa...and will be giving the engine a re paint and fit some new shiny bits...lol will take some pics of g/box and bits tommorow and post up...thanks...
  • 2 weeks later...
bit of an update,just finished giving the engine a revamp,still waiting for a few bits but you get the idea,i must say looks awesome so far,my mate has been helping me on the project who is pretty hand with spanners and a brush...:):)
heres the engine from this :(:(
to how it is now :):)
just got the clutch as well mc leod street twin
headers have been ceramicoated aswell to try and keep the heat from the engine bay...i also bought dudes old bonnet just incase i need extra cooling,i think it will be fine though as running the standard rad which is 30" wide,and have 2x14" pull fans being mounted to the rear of it...
couple of pics of the new g/box aswell keisler t56 6 speed with uprated carbon shifter pads,steal forks.input shaft,rated at 700whp...more than i will need,the clutch is rated to 900+hp i have gone a bit overkill on the drive train but if i decide to update to a procharger at a later date the ground work is all there...:)
also had custom adapter plate from keisler st the t56 would fit a sbc...
thats it for now engine should be mounted etc in next 2 weeks so will update then...thanks for looking...
piccies
piccy
:blink::blink:
me likey lots! good work so far fella
Nice one matey (btw, you have yet another PM :D )
Is that the stock sbc bellhousing your using, nice to know they adaptor plates are availabvle off the shelf.
Any decision on the diff and prop yet? Are you sticking with the Toyota diff (presumably LSD manual one)
i am going to use the stock rear diff set up and if needed change to a tt rear end which should be more than capable...
