Airbox lid.....
sykick
Hi All,
I need some advice on my airbox lid. One of the plastic clips has broken off of the top of the lid. I want to get a new one to ensure a good seal around the filter. Where can I get one for the j-spec, and is it the same as the uk-spec one?
rgds,
Marcus
Guest Martin F
Making the assumption that you have a TT, the part number is 17705-46100 and is the same for a J-spec and a UK spec.
If you look at the attached file i'm assuming it's the part that is labelled 17705 that you need.
I would be extremely suprised if any dealer had one in stock.
air cleaner.zip
The first time I tried to take my airbox lid off I did the exact same thing. I thought the damn thing opened up on a hinge from the bottom and ended up snapping one of the fasteners.
I tried super glue but it didn't last long.
I have now simply removed the box lid and used elastic bands to hold the panel filter in place. I am now getting more air-flow into the filter and there seems to be a bit more low end torque coming from the engine. It's also just slightly louder aswell.
Good enough result in the end.
