wilkorangerover Posted November 29, 2007 Share Posted November 29, 2007 will Boost Logic 525CC Injectors x 6 + Boost Logic Injector Piggy Tails x 6 make a difference to my bpu supra????? Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted November 29, 2007 Share Posted November 29, 2007 No Quote Link to comment Share on other sites More sharing options...
wilkorangerover Posted November 29, 2007 Author Share Posted November 29, 2007 are they for single turbo cars? Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 29, 2007 Share Posted November 29, 2007 Not without something to control them... HOWEVER something like an emanage will allow you to tweak the ignition/injectors which will release the power.. Quote Link to comment Share on other sites More sharing options...
Steviekid Posted November 29, 2007 Share Posted November 29, 2007 Not without something to control them... HOWEVER something like an emanage will allow you to tweak the ignition which will release the power.. Would an emanage not be able to do that with stock injectors too though? They're not maxed out at BPU are they? Quote Link to comment Share on other sites More sharing options...
JustGav Posted November 29, 2007 Share Posted November 29, 2007 Would an emanage not be able to do that with stock injectors too though? They're not maxed out at BPU are they? Oh yeah, it would control the stock injectors as well, however the point I was trying to make (badly) was that the injectors on their own would overfuel and would require a piggyback/standalone to tweak it back into line. A piggyback/standalone would also help iron any wrinkles in the BPU setup and configure the fueling (stock/otherwise) correctly. Out of interest, are you sure the boostlogic ones are for a TT and not an NA-T style conversion, 525cc is less than the usual UK 550's which are common on the supras in the US (since most of them are not imports and run 550s) Quote Link to comment Share on other sites More sharing options...
Homer Posted November 29, 2007 Share Posted November 29, 2007 Just to follow up on what Gav has said, check if they are low or high impedance as you might need a ressitor pack. Pretty pointless at BPU, unless you're planning much further down the road... Quote Link to comment Share on other sites More sharing options...
