Excel help again
tbourner
Another one for the experts.
Is there any way to make a formula that gives the value from a group of values, that is closest to the average?
The "=AVE()" formula gives the exact average, but I want to perform another function on one particular value in a range that is the average value, and it won't recognise it because the exact average is between 2 of the values.
Here's the one I've got working last night, I haven't made it nice and easy to understand like you have though!! :D So don't bother looking at the other 3 sheets just the first one.
We test HDDs in chassis, so I've put a cell in (C2) that allows the user to add the number of drives tested. This made it harder because the test range is always changing!
The results then go in E:G, numbers are I/O per second, so come up as 134.0233145 for example.
Column I is the average of the 3 runs for each drive.
Column K then tells which of the drives is the MIN, MAX or AVE running drive.
I've used column T as the drive average result, minus the average of all average results ( :confused: ). So the lowest value in T is the one closest to the average. Column K refers to this to get the AVE result, I've even made T in white text so (simple) users won't know it's there.
It's not correct but it works, feels like a bodge though.
