XP or Vista x64
Wez
If you are doing gaming, you are probably better sticking with XP32 unless the game specifically needs some silly Direct X10 from Vista.
Is DX10 due to be released for XP?
Its been available for download on torrent for some time as is SP3.
DX10 isnt going to be released for XP is it? as its one of the reasons to upgrade to vista whenever ive downloaded it from torrents its just dx9 rebadged
As for vista 64 ive tried it while running games, you loose a few FPS hardly noticable but some games, ie Bioshock and Gears of war (from what ive tried) hate vista 64, constantly freezing/crashing
Wait till there is more support for the 64bit version
Drivers arnt usually a problem anymore its program compatibility
Got 5 PC's in the house. Only got 1 thats 64bit but i put Vista64 on it just so that if i needed to use a 64bit app. I could.
Your going to have the same sort of issues regardless of whether you go for Vista or XP so if i were in your shoes, i would go for Vista.
Its nicer :p
Scott =op
If you wanted to try it and don't mind tinkering, you could create another partition on your hard disk and install Vista there (assuming you have access to a copy already).
You might even be able to hold Vista in a single large container file, rather like some people do with Linux.
I've had Vista 64 for about 9 month's or so I guess.
Initially it was a real pain in the arse, limited driver support from Nvidia, struggle to find drivers for old hardware like printers etc.
Personally, if I were going to go through again, and I was building a gaming machine, I would just go with the 32 bit version as a lot more games are developed on 32 bit machines. In fact, I've yet to see any game that has been developed to take advantage of the 64 bit processor.
I am currently running XP 32bit and was wondering about 64bit so I can use the extra memory, I have 4gb DDR2 1066Mhz but 32bit XP will only 3.5gb.
Think I will stick with 32bit, seems to be going alright now that I have added an 8800GT :D
