Daston Posted November 27, 2007 Share Posted November 27, 2007 Ok plan to go full BPU in Jan. To me this means Double Decatt Fuel pump Plugs FCD Exhaust Restrictor ring Intercooler (ok not really needed for BPU but hey) Now whats BPU+ and ++ and +++ etc all about? As I see hybrids as TPU (Tricky Performance Upgrade) and singles as MWAWOWPU (Might want a week off work performace upgrade) Link to comment Share on other sites More sharing options...
Scott Posted November 27, 2007 Share Posted November 27, 2007 Remember de-cat's Scott =op Link to comment Share on other sites More sharing options...
Daston Posted November 27, 2007 Author Share Posted November 27, 2007 oh yeah there are the car already Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 27, 2007 Share Posted November 27, 2007 You could keep adding to the spec with Performance upgrades hence the ++, for example a boost controller, uprated clutch, uprated fueling, piggyback ECU etc Link to comment Share on other sites More sharing options...
Inferno Posted November 27, 2007 Share Posted November 27, 2007 Basic Performance Upgrade™ (BPU™). This terms was coined by our founder Mark Tozer to best describe the basic set of performance modifications on a 1993-1998 Twin Turbo Supra. Instead of having to type out every basic mod a car had, we came up with this term. In it's simplest form it describes a Supra that is running elevated boost. In more detailed form the original BPU™ consisted of the following modifications: I. Downpipe. The downpipe replaces the factory CATS and allows for quicker turbo spooling and 1-2 psi of boost increase. Good for around 35-40 HP. II. Aftermarket Exhaust. Anytime you can free-up exhaust energy in a turbo car it is a good thing. The factory 2JZGTE engine with the BPU™ mods can flow quite a bit of exhaust gasses. Most aftermarket CAT-Back exhausts are good for around 15HP+ on a BPU™ Supra running 18psi of boost. III. Elevated Boost (17-18psi+). The major gain in HP and torque (up to 440rwhp and 410 ft.lbs of torque to the wheels) comes when you increase the boost in a Twin Turbo Supra. Increasing the boost can be done via a manual bleeder which allows for higher boost, but no control over boost levels. Manual boost controller, which uses a manual valve for adjusting boost levels (non-electronic). Electronic Boost Controller (most popular), which allows for in-cabin adjustment and regulation of boost pressure. IV. Boost Cut Controller (BCC). The GReddy BCC is an electronics interceptor device that modifies the manifold pressure signal (boost) to the factory ECU. The Toyota factory ECU in the 2JZGTE Supra has a factory imposed fuel-cut at 1 bar (14.7 psi) of boost. The BCC is adjustable and alters the factory fuel-cut level so higher boost can be run. Those four items are the foundation of the original BPU™ FAQ written for MKIV and typically produce anywhere from 440-500 HP (crankshaft) on both automatic and 6 speed 2JZGTE equipped cars. Numbers vary upon state of tune and vehicle condition but the formula works and is run in hundreds upon hundreds of Supras. This BPU™ term has become so popular throughout the world and the NET that it is often quoted in magazines and even by other car owners when describing a Supra TT. I have heard of BPU™+ and BPU™++, etc what is the difference? Answer: The first "+" comes with the addition of cam gears which can give you another 20hp. The second "+" in BPU™++ constitutes an "underdrive-pulley" which can give you another 5-7hp. The third "+" in BPU+++ comes with the addition of a front mount intercooler, the fourth "+" comes with fuel upgrade (injectors, pumps etc), the fifth "+" comes with ECU/computer upgrade. Link to comment Share on other sites More sharing options...
Scott Posted November 27, 2007 Share Posted November 27, 2007 Pretty sure your HP figures are about 100bhp high Scott =op Link to comment Share on other sites More sharing options...
Daston Posted November 27, 2007 Author Share Posted November 27, 2007 I have heard of BPU™+ and BPU™++, etc what is the difference? Answer: The first "+" comes with the addition of cam gears which can give you another 20hp. The second "+" in BPU™++ constitutes an "underdrive-pulley" which can give you another 5-7hp. The third "+" in BPU+++ comes with the addition of a front mount intercooler, the fourth "+" comes with fuel upgrade (injectors, pumps etc), the fifth "+" comes with ECU/computer upgrade. Ahh thanks man So with my fuel pump and posibly injectors as well as FMIC i would be BPU++ Link to comment Share on other sites More sharing options...
Homer Posted November 27, 2007 Share Posted November 27, 2007 It's a copy/paste from the Superstore site, the people who "created" the 'bpu' package for the Supra's. Hence, they are American Horse Power Link to comment Share on other sites More sharing options...
Homer Posted November 27, 2007 Share Posted November 27, 2007 Ahh thanks man So with my fuel pump and posibly injectors as well as FMIC i would be BPU++ If you want to call it that sure, go ahead. No one here uses the + bits since the supposed claims of HP gain made my Suprastore are b*llocks. It was just a technique to get people to buy needless stuff like the pulleys. Remember these were created back in the day when BPU was considered highly modified (10+ years ago) Link to comment Share on other sites More sharing options...
Scott Posted November 27, 2007 Share Posted November 27, 2007 Ahh that explains that then! Yeah i would say fuel pump and FMIC would make you BPU++ injectors would be +++ lol Scott =op Link to comment Share on other sites More sharing options...
Homer Posted November 27, 2007 Share Posted November 27, 2007 You guys are just making it up now Edit - if you have the injectors by default you need an ECU, so thats an extra + right there. Woot! Link to comment Share on other sites More sharing options...
Scott Posted November 27, 2007 Share Posted November 27, 2007 No were not... Magic Tree airfreshner, as long as its new car smell, counts as BPU++++ lol Scott =op Link to comment Share on other sites More sharing options...
RobSheffield Posted November 27, 2007 Share Posted November 27, 2007 And if its black its ++++++++ and if its a tuesday thats another + Link to comment Share on other sites More sharing options...
Guest mk47 Posted November 27, 2007 Share Posted November 27, 2007 Not to mention an AFR & EGT gauge so thats another ++ Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 27, 2007 Share Posted November 27, 2007 Am I right in saying though that there must come a point in the whole BPU +..++....+++ saga where you are spending money and the stock turbos are just not able to deliver anymore power?? also is there a point where BPU +++etc on an old set of TT's could be the death of them, this may be worth mentioning to the Noobies joining?? Link to comment Share on other sites More sharing options...
Scott Posted November 27, 2007 Share Posted November 27, 2007 God no, the airfreshner alone and the fact that its tuesday gives at least 50rwhp. According to the american dyno's anyway Scott =op Link to comment Share on other sites More sharing options...
Gaz6002 Posted November 27, 2007 Share Posted November 27, 2007 magic tree = 1 more + Link to comment Share on other sites More sharing options...
Homer Posted November 27, 2007 Share Posted November 27, 2007 Am I right in saying though that there must come a point in the whole BPU +..++....+++ saga where you are spending money and the stock turbos are just not able to deliver anymore power?? also is there a point where BPU +++etc on an old set of TT's could be the death of them, this may be worth mentioning to the Noobies joining?? It's a case of diminishing returns, plus some misinformation/bad assumptions E.g. the IC, you'll only see a gain if the stock one is shot. Same goes for fuel pump. A good service would release more HP than some of the mods mentioned. Link to comment Share on other sites More sharing options...
Scott Posted November 27, 2007 Share Posted November 27, 2007 Is the stock IC that good? I thought a FMIC would be much better, when the warmer weather is in anyway. MR2 one is pretty crap. Oh, i didn't mean for BHP. Well i did in a way, but i meant more with the intake temps. Scott =o Link to comment Share on other sites More sharing options...
tooquicktostop Posted November 27, 2007 Share Posted November 27, 2007 Is the stock IC that good? I thought a FMIC would be much better, when the warmer weather is in anyway. MR2 one is pretty crap. Oh, i didn't mean for BHP. Well i did in a way, but i meant more with the intake temps. Scott =o Is a large FMIC needed on the stock twin set up though, I dont think so, sending very large volumes of air to the stock system is a waste is it not ?? a good quality SMIC would work just as well ? Link to comment Share on other sites More sharing options...
Homer Posted November 27, 2007 Share Posted November 27, 2007 Is the stock IC that good? I thought a FMIC would be much better, when the warmer weather is in anyway. MR2 one is pretty crap. Oh, i didn't mean for BHP. Well i did in a way, but i meant more with the intake temps. Scott =o The stock will be fine, but obviously most of the ones floating around now are past their best (some I've seen are virtually useless!). The SMIC has a nice setup, fully ducted where air is actually drawn through the core. The FMIC (again on nearly all the cars I've seen at club meets) are unducted and due to it being in front of the rad air is being drawn though, only pushed. Link to comment Share on other sites More sharing options...
jamesmark Posted November 27, 2007 Share Posted November 27, 2007 Is a large FMIC needed on the stock twin set up though, I dont think so, sending very large volumes of air to the stock system is a waste is it not ?? a good quality SMIC would work just as well ? Totally agree a FMIC is pointless on a car that runs stock twins, but to go full BPU it always best to get a new SMIC. Unless yours is totally mint condition. Link to comment Share on other sites More sharing options...
couv3z Posted November 27, 2007 Share Posted November 27, 2007 wow, you TT biys like to ++ it all up to the nine degree once question tho if you went single or hybrid would that be APU? ( Advance perforance upgrade?) Link to comment Share on other sites More sharing options...
Homer Posted November 27, 2007 Share Posted November 27, 2007 once question tho if you went single or hybrid would that be APU? ( Advance perforance upgrade?) If we're using the terms Suprastore used then yes, single is known as APU. Hybrids were rarely used in the US so never got a specific term. As we're making it up as we go along, perhaps MPU (Medium performance upgrade) Link to comment Share on other sites More sharing options...
Daston Posted November 27, 2007 Author Share Posted November 27, 2007 The only reason I have gone for a FMIC is due to my new front bumper restricting air to the SMIC. Fuel pump wise I decided to play it safe Link to comment Share on other sites More sharing options...
