overdrive and slipcontrol lights flashing
Paul372
this has happened a couple of times now, driving along everythings fine then all of a sudden the overdrive and slip con lights on the dash just start flashing on and off alternately to each other. i have to pull over turn the car off to get the lights to go off and when i turn the car back on everythings seems fine again, i have no idea whats wrong could it be a senor going wrong? help please:(
yeah the spaniards are always going wrong:)
i had this mate. check the error codes, usually something to do with a bad signal from the trac control sensor (Gaz1 helped me find this - remember mate?). anyway, i found that theres a sensor that fits into the side of the gearbox (passenger side of the car), took that out, cleaned it, changed the gearbox fluid and hey presto, problem solved :)
indeed i do, glad it sorted it you have a good memory;)
Guest dangerousandy
My TRC seems to work on my UK spec auto when i PFD too hard in the wet (or hit a drain, bump in road etc!) but I can't seem to turn it off using the switch in the console! Is a gardian angel watching over me? O/D works fine!
