Jellybean Posted March 24, 2016 Share Posted March 24, 2016 Didn't want to assume I can reuse and find out they're made of chocolate and snap when I start removing. I have a 93 Supra and mine are fine, just need a little elbow grease to clean them up! I found it is just the plastic clips on the loom plugs can go brittle from heat under there over the years If you do figure out sizes , be good to know! Link to comment Share on other sites More sharing options...
alibabba Posted September 4, 2016 Share Posted September 4, 2016 will do, ive now done about 2/3rds of the lines, only the ones down under the airbox to the vsv under there and the actuator, not going to bother tho i think for now they seem ok, not hard at all and seem in good nic. i found that i needed to order a meter of 8mm because the 6mm is to tight for 2 of the pipes, not sure where people have got just the 3 sizes from!! you need 4 sizes,4mm for the small vac lines, i havint used any of the 5mm as yet so carnt comment on that, ive used like i said 90% of the 1 metre length of 6mm, id recommened getting 1.5m as its seem a popular size in the engine bay and i theres still a bit left to do using 6mm. and i bought 1 meter of 8mm for a few lines, you see the ones i mean when you do the job. id say 1.5m of 6mm, 2 meters of 4mm, 1 meter of 5mm and 1 meter of 8mm Did you end up using the 5mm hose? Link to comment Share on other sites More sharing options...
alibabba Posted September 4, 2016 Share Posted September 4, 2016 Oops, I've just seen the date. Sorry guys. But if someone can answer my question I appreciate it Link to comment Share on other sites More sharing options...
ianhid Posted September 4, 2016 Share Posted September 4, 2016 No, it doesn't look like I used the 5mm I bought, it's still sat in the spares box. I used 4, 6 and 8, didn't replace every single line on the car as some are complete pains to get to. I could do with about 15cm of 3mm (or a clamp/zip-tie) for one of my VSV lines as it has slipped off twice. 2 minute fix to put it back on, so I've not been overly bothered. Link to comment Share on other sites More sharing options...
Sheefa Posted September 12, 2018 Share Posted September 12, 2018 Thread Bump. I've ordered the following sizes: 4mm Gates - 2 Metres 5mm Gates - 1 Metre 6mm Gates - 1 Metre Also as a backup with special clamps: 4.5mm Glencoe Overbraid - 2 Metres 6.5mm Glencoe Overbraid - 2 Metres First plan when I get the Red beauty is to return all hosing to near as stock as possible (subject to condition). Will let you know how I get on and exact lengths/diameters used. Greg Link to comment Share on other sites More sharing options...
