miko_supra Posted November 25, 2007 Share Posted November 25, 2007 Think im going to replace all of these as i keep hearing people loosing boost because of tired old ones that are cracking. i still only want black hoses, not much of a fan of blue or red. what diameters will i need to order and wheres the best place? thanks in advance Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 15, 2008 Share Posted April 15, 2008 i would also like to know this info,cheers Quote Link to comment Share on other sites More sharing options...
miko_supra Posted April 15, 2008 Author Share Posted April 15, 2008 sizes needed were 4mm- 2 meters 5mm- 1 meter 6mm- 1 meter Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted April 15, 2008 Share Posted April 15, 2008 I think most will be about 4mm ID and there are plenty of shopes on ebay that sell the silicone tubing and in black too. I used 3mm ID and were quite tight in places. Quote Link to comment Share on other sites More sharing options...
phat supra Posted April 15, 2008 Share Posted April 15, 2008 cool i wanted this to but am goin for blue ones any idears where to get them from thanks Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 15, 2008 Share Posted April 15, 2008 hello, cheers for the advise, but whats with the dont use silicone hose on this forum then, how much do you think it would be to buy all hoses from toyota,. my car is a 94jdmTT,has 79,000-80,000 miles on it, generally the pipes seem ok but some are like china in that i know if i grab ahold of them they will crack into, also sure i have the 2nd turbo not coming in all the time, because sometimes it really goes and other times its just not right, i can feel there no 2nd tubbie, me thinks hose split somewhere Quote Link to comment Share on other sites More sharing options...
miko_supra Posted April 15, 2008 Author Share Posted April 15, 2008 hello, cheers for the advise, but whats with the dont use silicone hose on this forum then, how much do you think it would be to buy all hoses from toyota,. my car is a 94jdmTT,has 79,000-80,000 miles on it, generally the pipes seem ok but some are like china in that i know if i grab ahold of them they will crack into, also sure i have the 2nd turbo not coming in all the time, because sometimes it really goes and other times its just not right, i can feel there no 2nd tubbie, me thinks hose split somewhere dont rule out faulty vsv's as the cause of your 2nd turbo not coming in Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted April 15, 2008 Share Posted April 15, 2008 yeah ive been reading alot about them vsvs, one down the side by turbos seem a right pig to get at. did find one hose around the rear of the engine by the firewall just a few hours ago where one of the steel clips was sticking into it, got me plyers out and moved the clip away from the hose, theres a nice little cut in that hose now fromthe clip digging in to it, but dont think its gone all the way thru. Quote Link to comment Share on other sites More sharing options...
Angarak Posted April 15, 2008 Share Posted April 15, 2008 ...but whats with the dont use silicone hose on this forum then... Most silicon hose is not reinforced like the stock hoses. I think they are more prone to splitting and popping off IIRC. You can get silicon hoses with a reinforced lining but you will pay more for it. I havent a clue how cheap/expensive OEM ones are from Toyota - but Steve Manley (do a search) may do them cheaper than most other dealers. Quote Link to comment Share on other sites More sharing options...
Homer Posted April 15, 2008 Share Posted April 15, 2008 As mentioned, don't bother with low grade silicon hose. Use the high quality reinforced lines. The strange thing is it's actually cheaper than the 'bling' coloured cr*p! and certainly cheaper than Toyota. http://www.fuelsystem.co.uk/ Quote Link to comment Share on other sites More sharing options...
jimmy_supra Posted July 2, 2008 Share Posted July 2, 2008 As mentioned, don't bother with low grade silicon hose. Use the high quality reinforced lines. The strange thing is it's actually cheaper than the 'bling' coloured cr*p! and certainly cheaper than Toyota. http://www.fuelsystem.co.uk/ Which pipes did you buy from here? How much of each size do I need thanks. Quote Link to comment Share on other sites More sharing options...
Angarak Posted July 2, 2008 Share Posted July 2, 2008 See post #3 in this thread regarding sizes/lengths: http://www.fuelsystem.co.uk/Hose%20Connections.pdf Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 2, 2008 Share Posted July 2, 2008 Has anyone priced up a full engine vac, pressure and breather hose kit from someone like Nic? I would say a complete set of new stock hoses for the TT and breather system would make a good Christmas present for a lot of people Quote Link to comment Share on other sites More sharing options...
AndrewOW Posted July 2, 2008 Share Posted July 2, 2008 When I had my boost problem on my second turbo recently, I replaced the split pipe with a 4mm reinforced fuel line pipe. Its really cheap, and can withstand up to 14bar, so easily up to the job. It looks good in black too. Quote Link to comment Share on other sites More sharing options...
jimmy_supra Posted July 3, 2008 Share Posted July 3, 2008 See post #3 in this thread regarding sizes/lengths: http://www.fuelsystem.co.uk/Hose%20Connections.pdf The vacuum hoses only go up to a maximum diameter of 4.5mm, the sizes quoted above go up to 6mm. So which pipes do I need to get as I want to get it right first time. Thanks Quote Link to comment Share on other sites More sharing options...
Nic Posted July 3, 2008 Share Posted July 3, 2008 Can confirm that these diameter and lengths are correct? If they are I can supply HKS or GReddy hoses in these sizes. 4mm- 2 meters 5mm- 1 meter 6mm- 1 meter Quote Link to comment Share on other sites More sharing options...
Supradoopa Posted July 3, 2008 Share Posted July 3, 2008 Hmmm what sort of price would we be looking at Nic? PM if you want Quote Link to comment Share on other sites More sharing options...
Thomas.B Posted April 8, 2012 Share Posted April 8, 2012 Bumping an old thread. I am going to tidy up my engine room and the vacuum hoses that are there now are shitty quality so where going to change as many possible without removing any larger parts. Does anyone know about how much I'll be needing to change the visible ones? If I remember correctly it'll be mostly 4mm? Cheers Quote Link to comment Share on other sites More sharing options...
Lude Posted April 8, 2012 Share Posted April 8, 2012 4mm & 6mm i used. just order plenty of it, from ebay, better have too much than too little. nice thread resurection btw Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 11, 2014 Share Posted March 11, 2014 does anyone know the best place to buy high quality 4/5/6 mm reinforced vac lines from? in black Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 11, 2014 Share Posted March 11, 2014 Wurth. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 11, 2014 Share Posted March 11, 2014 thanks chris, also found this stuff, http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330803508813 Wurth. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 11, 2014 Share Posted March 11, 2014 thanks chris, also found this stuff, http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=330803508813 That's fine, too. Gates is good gear! Anything's better than plain silicone though. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted March 11, 2014 Share Posted March 11, 2014 cheers for that. think this is the stuff il get then as the sizes on the wurth site were a little off. this gates stuff is 4/5/6mm cheap ish too. just waiting on an closeup photo of the gates pipework now, just to make sure of what it looks like, what to stay as close to oem look as possible. That's fine, too. Gates is good gear! Anything's better than plain silicone though. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 11, 2014 Share Posted March 11, 2014 It looks just like stock. I use it when the Wurth rep has disappeared. Quote Link to comment Share on other sites More sharing options...
