Becks Posted November 24, 2007 Share Posted November 24, 2007 Hi I have got a knocking on the rear suspention, So i took it to the garage and they said that it is the rear wishbone bushes have gone, He got in contact with there supplyer and they could not get hold of them Please can some one tell me where i can get them from?? Its the upper wishbone both sides that has gone and also its an N/A:search: Thanks Becks Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted November 24, 2007 Share Posted November 24, 2007 I would say Toyota, or contact Nic on here if your local toyota give any issues... Quote Link to comment Share on other sites More sharing options...
Homer Posted November 25, 2007 Share Posted November 25, 2007 Unfortunately you cannot get stock replacement bushes, you need to buy the entire arm that comes with the bushes already fitted. An option is to use aftermarket poly bushes but this will harm the ride comfort. They are also very hard work to fit, most places struggle to do them. As mentioned by Rob, if you need them on short order use Steve Manley in Toyota Oxford, if you can wait 5-6 weeks then Nic can get them for a much lower price. Quote Link to comment Share on other sites More sharing options...
SatSport Posted November 25, 2007 Share Posted November 25, 2007 these are excellent..... http://shopping.yahoo.com/s:Suspension%20Components:22606-Model=Toyota%20Supra:22607-Year=1993 Quote Link to comment Share on other sites More sharing options...
Becks Posted November 25, 2007 Author Share Posted November 25, 2007 Unfortunately you cannot get stock replacement bushes, you need to buy the entire arm that comes with the bushes already fitted. An option is to use aftermarket poly bushes but this will harm the ride comfort. They are also very hard work to fit, most places struggle to do them. As mentioned by Rob, if you need them on short order use Steve Manley in Toyota Oxford, if you can wait 5-6 weeks then Nic can get them for a much lower price. Any ideas where i can get aftermarket poly bushes from, Sound like its going to be expencive just befor crimbo aswell:( Quote Link to comment Share on other sites More sharing options...
Homer Posted November 25, 2007 Share Posted November 25, 2007 Any ideas where i can get aftermarket poly bushes from, Sound like its going to be expencive just befor crimbo aswell:( See link above by Satsport. I've not experienced them myself but the feedback I've seen on these is very mixed. They are a nightmare to change, some garages have failed to remove the stock ones even with 10 ton presses. Make sure you get the price agreed beforehand otherwise the bill could be far more than replacing with stock suspension. Also keep in mind that the ball joints cannot be replaced so at least with stock replacements you get those renewed too. Quote Link to comment Share on other sites More sharing options...
Mike B Posted November 25, 2007 Share Posted November 25, 2007 mmmm... I bought an entire poly bush set for my last car. Fitted the fronts and had a sense of humour failure... never fitted the rears. you fancy having a go? I have a complete rear poly bush set here, bought from mvp. The old bushes can be harsh to get out, but in the end i had a good technique with a very big vice. You'd only need to swap the lower arm bushes I guess. (4) edit - sorry just reread.. upper bushes.. i have the set anyway. also check that the garage is not winding you up... quite a few sups have knocking noises from the back that are not bush related. Quote Link to comment Share on other sites More sharing options...
RobSheffield Posted November 25, 2007 Share Posted November 25, 2007 also check that the garage is not winding you up... quite a few sups have knocking noises from the back that are not bush related. Good advice! Quote Link to comment Share on other sites More sharing options...
DannoSupra Posted November 25, 2007 Share Posted November 25, 2007 If you do get polybushes... Best way to remove the old ones, is to burn the F***er's out! Quote Link to comment Share on other sites More sharing options...
jaymdee Posted November 25, 2007 Share Posted November 25, 2007 I had knocking and it turned out to be the top 2 rings on the springs knocking as I drove over bumps, as they weren't a very good match to the dampers Quote Link to comment Share on other sites More sharing options...
Becks Posted November 25, 2007 Author Share Posted November 25, 2007 Its defo thewishbone mounts he saw then and my boyfriend showed me:( Quote Link to comment Share on other sites More sharing options...
colsoop Posted November 25, 2007 Share Posted November 25, 2007 Labour on bushes would probably cost the same amount as replacing the knackered arm. Quote Link to comment Share on other sites More sharing options...
Supra-Brett Posted November 25, 2007 Share Posted November 25, 2007 Mine had the same problem. Toyota in Reading quoted me around £170 for a new upper suspension arm so they arnt cheap. In the end, i got one that looked like new from a scrappers for £80. It will take you some time to phone round and find one, but its worth it if you can get a good one. Quote Link to comment Share on other sites More sharing options...
Rob Posted November 25, 2007 Share Posted November 25, 2007 Deano H is scrapping his NA, so may have these arms to sell. Quote Link to comment Share on other sites More sharing options...
