lockys96 Posted November 23, 2007 Share Posted November 23, 2007 my car wouldnt go above 800 before i fitted a turbo blanket, and wrapped downpipe. now on full chat it see's 900 EGT but never rises above. is this common thing to happen, does the heat get kept in more, and therefore increases EGT? the EGT sensor is directly into the turbo exhaust housing Quote Link to comment Share on other sites More sharing options...
b_have Posted November 23, 2007 Share Posted November 23, 2007 The hotter the better Its the temp of the exhaust as it leaves the combustion chamber thats important, once in the turbo, heat converts to motion energy. Ideally, egt should be measured as near to the exhaust port as possible. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 23, 2007 Author Share Posted November 23, 2007 so would you say that this temp at 900 is good where my sensor is placed? Quote Link to comment Share on other sites More sharing options...
Sean1933 Posted November 24, 2007 Share Posted November 24, 2007 I would say so yes . It basically means you have less heat loss = less heat energy loss = more power. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted November 24, 2007 Share Posted November 24, 2007 That is why people heat wrap, to keep the heat in and reduce engine bay temps. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 24, 2007 Author Share Posted November 24, 2007 looks like its doing its job then Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 today my reading was 950. hmmm Quote Link to comment Share on other sites More sharing options...
uk-rich Posted November 25, 2007 Share Posted November 25, 2007 have the afr's changed at all ? Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 hi rich, i have no idea of telling. think i need to install a AFR ratio meter Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 25, 2007 Share Posted November 25, 2007 today my reading was 950. hmmm What boost was this at.. and what gear??? Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 i was only using 2nd and 3rd, i think it was acheived in 3rd at 1.0bar Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 25, 2007 Share Posted November 25, 2007 i was only using 2nd and 3rd, i think it was acheived in 3rd at 1.0bar Hmm thats a litle high mate... I have my manifold/DP heat wrapped..... What ECU? What were your AFR's? Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 its a link g3 thing. ryan will know what the AFR were, as he tuned it very well. Quote Link to comment Share on other sites More sharing options...
suprafan72 Posted November 25, 2007 Share Posted November 25, 2007 Im guessing 11:5 TO 11:7.. Ryan does things properly..... Im sure its easy sortable... The turbo blanket ad manifold will be raising EGT's.. I guess you will be getting higher EGT's on cruise and idle as well. Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 Im guessing 11:5 TO 11:7.. Ryan does things properly..... Im sure its easy sortable... The turbo blanket ad manifold will be raising EGT's.. I guess you will be getting higher EGT's on cruise and idle as well. with the heat kept in on that turbo, your correct. cruising can be 600-700 with just a light dab of the throttle is hops up to 800. would i need the car tweaked in terms of tunning due to fitting the blanket Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted November 25, 2007 Share Posted November 25, 2007 Sounds like something may have changed then mate with all the other bits you have had done recently. As never went above 750c when it left me hence why i set the warning gauge at 800c. Can see a Blanket raising the temps maybe 100c but not 200c Best thing to do is arrange for a checkup Ryan Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 with you? Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted November 25, 2007 Share Posted November 25, 2007 Check your e-mail Quote Link to comment Share on other sites More sharing options...
lockys96 Posted November 25, 2007 Author Share Posted November 25, 2007 Check your e-mail thanks, check ure phone:D Quote Link to comment Share on other sites More sharing options...
lockys96 Posted December 2, 2007 Author Share Posted December 2, 2007 all sorted today, raised fuel pressure, and adjusted the map. made a few more ponies, 523hp fly or 448whp @ 1.4bar. in the garage for winter hide away Quote Link to comment Share on other sites More sharing options...
Ryan.G Posted December 2, 2007 Share Posted December 2, 2007 Made that at 1.3bar bud but ran out of time to pump up the boost anymore. But 448bhp at the wheels is enough for the winter Ryan Quote Link to comment Share on other sites More sharing options...
