wilkorangerover Posted November 23, 2007 Share Posted November 23, 2007 whats the best way to get, to get the best peformance out of an auto box for speed and reaction is it MANU mode and second gear??? is it ok to keep changing gear manually in MANU mode? all i do is drive in D all the time Link to comment Share on other sites More sharing options...
ManwithSupra Posted November 23, 2007 Share Posted November 23, 2007 Switch off Overdrive and plant it ! Well thats what i do anyway.... using manu mode is fine it wont damage the box as your are just taking control of when the gear is changed. Manu mode is a bit more fun but i dont think there is a benefit of quicker gear changes when using it... i wait to be corrected. In manu mode L 2 and D are the gears you use so gears 1,2,3 overdrive is disabled so 120 leptons is your max Link to comment Share on other sites More sharing options...
juanchan Posted November 23, 2007 Share Posted November 23, 2007 In manu mode L 2 and D are the gears you use so gears 1,2,3 overdrive is disabled so 120 leptons is your max I'm sure mine does over 120 in 3rd. Could be wrong though. When I use manu mode, my autobox still kicks down. Chatting to Hoff a few weeks back, he said his doesn't. Anyone any ideas why? He's got an NA, mine's a UK. Link to comment Share on other sites More sharing options...
hoff Posted November 23, 2007 Share Posted November 23, 2007 When you are in manu mode and reach the higher leptons and therefore revving the arse of the car the box will then select 4th. Link to comment Share on other sites More sharing options...
hoff Posted November 23, 2007 Share Posted November 23, 2007 This will help explain it http://www.mkivsupra.net/vbb/showthread.php?t=86128 Link to comment Share on other sites More sharing options...
AndyT Posted November 23, 2007 Share Posted November 23, 2007 This will help explain it http://www.mkivsupra.net/vbb/showthread.php?t=86128 Beat me to it. Link to comment Share on other sites More sharing options...
juanchan Posted November 23, 2007 Share Posted November 23, 2007 When you are in manu mode and reach the higher leptons and therefore revving the arse of the car the box will then select 4th. Can't say as I've ever hit the redline in 3rd gear on the roads I'm sure I've read that autobox thread before, now that you mention it. So if I avoid putting my foot right to the floor, according to that post, it should hold it in 3rd. I'll have to try it next time I'm out. Link to comment Share on other sites More sharing options...
hoff Posted November 23, 2007 Share Posted November 23, 2007 I think yeh. Ive been driving in manu mode for a while but not had the opportunity to really test it. If you know what I mean;) Link to comment Share on other sites More sharing options...
juanchan Posted November 23, 2007 Share Posted November 23, 2007 I think yeh. Ive been driving in manu mode for a while but not had the opportunity to really test it. If you know what I mean;) Always know what ya mean I'm usually lazy and sit in D with overdrive on. I start faffing with it when I want to have a bit more fun Link to comment Share on other sites More sharing options...
hoff Posted November 23, 2007 Share Posted November 23, 2007 As do I. But I have a small leak from the autobox so changes in auto mode are a little lumpy. Im fixing it next week, well my GF's brother is:D But he's been saying that for 3 weeks:taped: Link to comment Share on other sites More sharing options...
