auto tt bpu
wilkorangerover
Switch off Overdrive and plant it !
Well thats what i do anyway.... using manu mode is fine it wont damage the box as your are just taking control of when the gear is changed.
Manu mode is a bit more fun but i dont think there is a benefit of quicker gear changes when using it... i wait to be corrected.
In manu mode L 2 and D are the gears you use so gears 1,2,3 overdrive is disabled so 120 leptons is your max
I'm sure mine does over 120 in 3rd. Could be wrong though.
When I use manu mode, my autobox still kicks down. Chatting to Hoff a few weeks back, he said his doesn't. Anyone any ideas why? He's got an NA, mine's a UK.
When you are in manu mode and reach the higher leptons and therefore revving the arse of the car the box will then select 4th.
Can't say as I've ever hit the redline in 3rd gear on the roads :D
I'm sure I've read that autobox thread before, now that you mention it. So if I avoid putting my foot right to the floor, according to that post, it should hold it in 3rd. I'll have to try it next time I'm out.
I think yeh. Ive been driving in manu mode for a while but not had the opportunity to really test it. If you know what I mean;)
Always know what ya mean :D
I'm usually lazy and sit in D with overdrive on. I start faffing with it when I want to have a bit more fun :eyebrows:
