iaintslow Posted November 22, 2007 Share Posted November 22, 2007 Where do you guys install these? Stock sensor hole is way too small. Thanks Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 22, 2007 Share Posted November 22, 2007 Drill it out and re tap? Or you can get nasty hose adaptors to go in the top hose. I only use mechanical gauges, unless running a digiatl dash, I just love their simplicity and the good ones are usually MORE accurate than electronic gauges. Quote Link to comment Share on other sites More sharing options...
Supra Pilot Posted November 22, 2007 Share Posted November 22, 2007 Hi Chris, where do you suggest tapping a hole for this? (other than stock position) Quote Link to comment Share on other sites More sharing options...
iaintslow Posted November 22, 2007 Author Share Posted November 22, 2007 See probe and adapter is so big, its like 3/4" Can i just get T connector and install it into the heater hose in the back of the head? How is the tempereture there compared to stock outlet location? Quote Link to comment Share on other sites More sharing options...
Digsy Posted November 23, 2007 Share Posted November 23, 2007 I believe that the heater takeoff is between the head and the block, so the coolant won't be as hot as it is at the main coolant outlet. Quote Link to comment Share on other sites More sharing options...
bignum Posted November 24, 2007 Share Posted November 24, 2007 I fitted 1 of those nasty adapters, looks shite but works a treat, and used an old revotek oil temp gauge that looks shit aswell but again does the job, Quote Link to comment Share on other sites More sharing options...
