Supra Pilot Posted November 21, 2007 Share Posted November 21, 2007 As per attached photo... Anyone concur regard the unit on the right of the standard boost unit? I believe it's a 'boost sensor' for a boost controller! Thanks Link to comment Share on other sites More sharing options...
miko_supra Posted November 21, 2007 Share Posted November 21, 2007 not 100% but i think your right by the looks of it. a better picture of the piping used for the sensor might help too Link to comment Share on other sites More sharing options...
Homer Posted November 21, 2007 Share Posted November 21, 2007 Yep, thats a boost sensor for either a boost gauge, ECU or boost controller. Plumbed into the wrong place I might add... not a good idea to Tee it into the FPR boost reference. Link to comment Share on other sites More sharing options...
Ryan.G Posted November 22, 2007 Share Posted November 22, 2007 Its a Map sensor for an Apexi AVCR boost controller Link to comment Share on other sites More sharing options...
Supra Pilot Posted November 22, 2007 Author Share Posted November 22, 2007 Wayhayy 10 points.... Ryan is spot on, it is indeed an AVCR map sensor... I also found out earlier today as I had a proper look myself this morning.... Thanks guys Oh and Homer, why is the location bad? Seems plumbed into the Intake plenum. Link to comment Share on other sites More sharing options...
Homer Posted November 22, 2007 Share Posted November 22, 2007 Oh and Homer, why is the location bad? Seems plumbed into the Intake plenum. 2nd thoughts I might well be wrong here. It looked like it was tee'd into the fpr pressure feed, but am not sure. If it is then it's a risk as you don't want a leak/blown hose on that line. Best to leave the FPR feed as simple and well secured as possible. Link to comment Share on other sites More sharing options...
