ESD knowledge?
tbourner
Anyone know about ESD stuff? I'm trying to set up our EPA in our new lab and have a problem with 1 bench.
I've got the ESD wrist strap plug point to screw to the front of the bench, which is reading just under 1M to the eye, then a yellow ESD lead which reads just over 1M from one eye to the other (about 1.5m long).
I held the 2 together and measured from the wrist strap point to the grounding point on the wall which I'd bolted the yellow cable to - just over 2M, which is correct.
BUT, as soon as I put both the eyes (which I was holding together) onto the same bolt (bolt is rivetted to the ESD mat on the bench top, and protrudes under the bench) and put a nut on it to hold them in place, the reading from wrist strap point to the grounding point goes up to 17M!!!!
So the way I see it, the voltage from my DVM is choosing to go down one wire, up the bolt, around the bench top a couple of times, down the same bolt and along the other wire to the ground point!!! WTF!!!!
