advice on body work, any sprayers in here ?
supra steveo
following on from me being smacked up the back end by a german and leaving me with the pics below what will happen ? i would like the rear spatz taken off and new ones put on and the body work on the rear sorted out once and for all, but something tells me that its not going to be that simple, another thing i want to try and do is get the colour changed as i want most of the back end sprayed
if you have met me i think i will have pointed out the state of the back end and the mess that the company who put the spatz on has made, you can see the body bodge on the 4th picture
behind the spatz are massive blobs of mastic i am abit cheesed off at the way the were put on
I'm afraid that that is a pretty std way of attaching body kits, its usually Sikaflex which is an adhesive, that and self tappers which can either be removed ore left once set, the only way you will get that spat to reattach is to use said adhesive, with something to press the spat against the bumper while it sets, and then re blend it in and spray, but unfortunately where its cracked the paint, you would probably need to take it back to the plastic, re prime and paint, or it will just crack again, so a decent body shop job really.
