TT Igniter/Top rad hose/Waterpump/lots o bits
StuartW
All sorted now cheers
As above..Basically i bought a crashed J Spec TT engine and need all parts that are not attatched to the engine (Engine bay stuff i.e igniter,wiring,etc) and parts that where damaged. Got pas resevoir.
Need
Clutch resevoir heat deflector
Ignitor
Wiring loom
Top rad hose
Waterpump
Spark plug/cam covers
Think i need resistor pack too as i am running n/a 650 inj. Think high imp..Someone pls correct me
Many Thanks
Knightrider
n/a 650 injectors? you sure?
Yes and they are high impedance, But i now going Sard800CC
My car is an N/A-T capable of 500FWHP
The Prescision 650's i have will fit a TT too if you use an n/a rail
I now have HKS rail. This is fact as i do all my own work
Thanks
Knightrider
Hi,
make sure the sard 800cc are top feed , if they are low imp then you need resistor pack. 650 will be good for 550hp.
I have :
1:cam cover
2:spark plug cover
3:ignitor
4:top rad hose
5:new and used oil pump
Remember to tig weld the timing star on the crank pickup, else you will have problems in the long run.
Ignitor - as in ignitor pack? Yes please
Spark plug/cam covers (standard cam covers and blue plug cover) Got blue plug covers just need big greeen plastic thing with toyota 3000....lesbian turbo
Top rad hose (shiney one) Oh yes the stainless type (Got the cast alu elbow)Waterpump - used but in good nick
I have all these parts sitting in the garage
Prices please bud?
Hi,
I have :
1:cam cover Std?2:spark plug cover
3:ignitor
4:top rad hose Is this all rubber or stainless?
Done
Hi Michel, Think i am nearly gettin organised;)
Any idea of prices on these parts please?
Also My oil pump is fine, was after a waterpump please.
Its a lot of bits stock and aftermarket i gotta organise so been a bit of an uphill struggle!
Many thanks for your advice:D
