Race built TH400 with transbrake 3800 or 4500/5000 TC
Terminator
its only 3 gears, so only for track use, right?
It has three gears, third being very similar to third on the standard auto box. I was going to add a Gear Vendors unit, to give the box overdrive in each forward gear. So effectively a six speed auto. It is a manual auto so you select the point at wich you change gear with the sequential shift mecanisim. There are guys who use these boxes on the road but most are used on the track. If you want perfect launches time after time then this is the box to use. This box is not a standard TH400, all internal componants have been uprated to give very high strength, it will take what ever power you can throw at it.
My plans take me down a different route, this box is just taking up space in the garage now.
  • 2 weeks later...
