Rob Posted November 15, 2007 Share Posted November 15, 2007 I'm a bit concerned about this now. My NA failed it's MOT on corrosion to the rear discs and a brake pipe. As I'm trying to be a cheapskate, I had the discs skimmed yesterday, they look lovely now, but I made the mistake of not telling the guy that the minimum thickness is to be 15mm. A measure with just a ruler and they look like being 14mm at best, I'll check with a Vernier when I get home. My thoughts are that I'll just put it back together for the re-test and source some replacement discs later. It failed on corrosion so I presume the MOT tester will just visually inspect that element, will he check the thickness against some database? Am I going to die in a crash? Quote Link to comment Share on other sites More sharing options...
Pete Posted November 15, 2007 Share Posted November 15, 2007 Just buy some new brakes. It's not worth scrimping on. Quote Link to comment Share on other sites More sharing options...
Rob Posted November 15, 2007 Author Share Posted November 15, 2007 Yeah, I kinda know that, but I've got to get the MOT this weekend so we can use both cars again. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 15, 2007 Share Posted November 15, 2007 He won't measure them unless they look stupidly thin. Quote Link to comment Share on other sites More sharing options...
AndyT Posted November 15, 2007 Share Posted November 15, 2007 I'm a bit concerned about this now. My NA failed it's MOT on corrosion to the rear discs and a brake pipe. As I'm trying to be a cheapskate, I had the discs skimmed yesterday, they look lovely now, but I made the mistake of not telling the guy that the minimum thickness is to be 15mm. A measure with just a ruler and they look like being 14mm at best, I'll check with a Vernier when I get home. My thoughts are that I'll just put it back together for the re-test and source some replacement discs later. It failed on corrosion so I presume the MOT tester will just visually inspect that element, will he check the thickness against some database? Am I going to die in a crash? Mine failed on this too. I put new ones on. Quote Link to comment Share on other sites More sharing options...
merckx Posted November 15, 2007 Share Posted November 15, 2007 My thoughts are that I'll just put it back together for the re-test and source some replacement discs later. The sensible thing to do. Quote Link to comment Share on other sites More sharing options...
Rob Posted November 15, 2007 Author Share Posted November 15, 2007 After christmas. Rusty brake pipe though? The little 1" of exposed pipe where it joins the flexi-hose connector has some surface rust on it. The whole joint is covered with the same. If I need to replace the pipe, how far back does it go into the bodywork? Is it even possible? Quote Link to comment Share on other sites More sharing options...
