Wazz72 Posted November 14, 2007 Share Posted November 14, 2007 Whats the difference between the NA, and the TT O2 sensors, except that the NA has 2 and the TT 1. Are they the same sensor? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 14, 2007 Share Posted November 14, 2007 No they are different, the TT has different plug and more wires. Quote Link to comment Share on other sites More sharing options...
JohnnyW Posted November 15, 2007 Share Posted November 15, 2007 You must be a busy man sending out all these 02 sensors Nic! You can tell that petrol prices are going through the roof everyone is buying them up to save a few quid Fitted mine the other week, has made a big difference. Thanks for your help with it! Quote Link to comment Share on other sites More sharing options...
bondinho Posted November 27, 2007 Share Posted November 27, 2007 Sorry for bringing this up from a couple of weeks ago, but I've fitted my new O2 sensors and the petrol consumption is still the same as before, and the idle is a bit erratic on start up since fitting them Stupid question maybe, but do the gaskets have to be fitted a specific way around? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 27, 2007 Share Posted November 27, 2007 Sorry for bringing this up from a couple of weeks ago, but I've fitted my new O2 sensors and the petrol consumption is still the same as before, and the idle is a bit erratic on start up since fitting them Stupid question maybe, but do the gaskets have to be fitted a specific way around? It doesn't matter which way around the gasket goes. Have you tried resetting the ECU? Disconnect the battery for a 10mins or so, then reconnect. It may not tick-over and be a bit lumpy for the first few miles, but after it relearns the settings it should be fine. Quote Link to comment Share on other sites More sharing options...
Smellywelshman Posted November 27, 2007 Share Posted November 27, 2007 How much are you selling these for Nic? A j-spec TT one. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 27, 2007 Share Posted November 27, 2007 How much are you selling these for Nic? A j-spec TT one. Hi The O2 sensors are £82 each including postage. cheers Quote Link to comment Share on other sites More sharing options...
bondinho Posted November 27, 2007 Share Posted November 27, 2007 It doesn't matter which way around the gasket goes. Have you tried resetting the ECU? Disconnect the battery for a 10mins or so, then reconnect. It may not tick-over and be a bit lumpy for the first few miles, but after it relearns the settings it should be fine. I was going to try the ECU reset this weekend, hopefully that will sort the idle. Maybe the petrol consumption will pick up after that too Cheers Nic. Quote Link to comment Share on other sites More sharing options...
