Dnk Posted November 14, 2007 Share Posted November 14, 2007 A good mate of mine with a uk spec is after new suspension so i thought i'd ask you guys for some input on Teins Hks etc Ive got O/E shocks with the Eibach lowering springs and im very happy with the end result, not to low or to stiff. Your opinions on differant kits would be appreciated but preferably if youve actually got a kit fitted. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 14, 2007 Share Posted November 14, 2007 look on ebay as from sat/sunday i have loads of stuff for sale from japan;) Link to comment Share on other sites More sharing options...
AndyT Posted November 14, 2007 Share Posted November 14, 2007 look on ebay as from sat/sunday i have loads of stuff for sale from japan;) Will you keep us posted and link when your stuffs available please Jurgen. Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2007 Author Share Posted November 14, 2007 look on ebay as from sat/sunday i have loads of stuff for sale from japan;) Cheers but before he buys im after info on how good any of these aftermarket kits are. Some just seem to cheap to me so im interested to see what anyone thinks after say a year of use on these kits or longer preferably. They all look great in the adds and backed up by the makers saying there great and the best etc but i want to know do they last the test of time and not just look great in the box. Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 I have had Eibach/UK I was glad to remove. HKS hypermax 2. Decent, typical jap kit, oversprung. JIC Magic with UK valving. Much better dampers for road use, height adjustment at the base without and effect on springs, but way over sprung, so I am currently fitting softer JIC springs and the optional helper springs. Hypermax 2 were good on track, but I was never able to use them above about 16 on the 30 point adjustment as the car wa so stiff it lost all grip and dosed either end at will. "IF" I lived on the mainland I would be going to Mr Wilson and have it done properly. Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2007 Author Share Posted November 14, 2007 I have had Eibach/UK I was glad to remove. HKS hypermax 2. Decent, typical jap kit, oversprung. JIC Magic with UK valving. Much better dampers for road use, height adjustment at the base without and effect on springs, but way over sprung, so I am currently fitting softer JIC springs and the optional helper springs. Hypermax 2 were good on track, but I was never able to use them above about 16 on the 30 point adjustment as the car wa so stiff it lost all grip and dosed either end at will. "IF" I lived on the mainland I would be going to Mr Wilson and have it done properly. Thanks for the input, you didnt like the Eibachs then ? Link to comment Share on other sites More sharing options...
AndyT Posted November 14, 2007 Share Posted November 14, 2007 Chris Wilson " I can supply dampers and springs to run any ride height within reason, £1250 fitted with a full geo reset. Based on new European Bilsteins and my own custom springs. If you have the yellow Bilsteins on yours already I can remove, modify and refit with modded ride height. In fact I can anything suspension related." Can't do better imo. And you can ask him to set the front toe / camber so the car is easier to drive and catch if things get unruly. Will be my only port of call when suspension time is due. Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 Thanks for the input, you didnt like the Eibachs then ? Hated them, front was too low, and sturts pumped themselves up in the lower position it would seem and ride was awful. Mind you my local roads are dug every week by some outfit or other. When I fitted a proper coil over kit, traction off the line was miles better and the car felt much more stable less prone to drifting. Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 Personally i think fitting new suspension without an expert geometry setup is like buying a toothbrush without toothpaste!. Link to comment Share on other sites More sharing options...
AndyT Posted November 14, 2007 Share Posted November 14, 2007 Personally i think fitting new suspension without an expert geometry setup is like buying a toothbrush without toothpaste!. Finding local experts that know the stuff is like looking for hens teeth too. Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2007 Author Share Posted November 14, 2007 Personally i think fitting new suspension without an expert geometry setup is like buying a toothbrush without toothpaste!. At the moment he's just trying to avoid an expensive mistake in buying the wrong kit or springs and dampers. Link to comment Share on other sites More sharing options...
suprafan72 Posted November 14, 2007 Share Posted November 14, 2007 Chris Wilson is def your man for this Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 At the moment he's just trying to avoid an expensive mistake in buying the wrong kit or springs and dampers. Maybe all his car needs is a good geometry setup rather than a suspension change? If the Geo is wrong - no suspension will make it good. Link to comment Share on other sites More sharing options...
CJ Posted November 14, 2007 Share Posted November 14, 2007 .... "IF" I lived on the mainland I would be going to Mr Wilson and have it done properly. I agree. The problem with opinions off members is that the majority of them (and I include me) would not really know what a good set up felt like anyway. Link to comment Share on other sites More sharing options...
ManwithSupra Posted November 14, 2007 Share Posted November 14, 2007 Does anyone know of a good company to do a geo setup in hampshire? Link to comment Share on other sites More sharing options...
hoff Posted November 14, 2007 Share Posted November 14, 2007 Maybe all his car needs is a good geometry setup rather than a suspension change? If the Geo is wrong - no suspension will make it good. Yeh, get that done 1st and see how it feels:) Link to comment Share on other sites More sharing options...
heckler Posted November 14, 2007 Share Posted November 14, 2007 Does anyone know of a good company to do a geo setup in hampshire? same here Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted November 14, 2007 Share Posted November 14, 2007 Will you keep us posted and link when your stuffs available please Jurgen. yep once its all listed i will add thread Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 IMHO I would rather have fresh stock suspension with 18" and propery geometry than all the fancy suspension you could buy with bad or stock geometry. G/Tee I'd beat you around any B road! if that was the case lol Link to comment Share on other sites More sharing options...
Scooter Posted November 14, 2007 Share Posted November 14, 2007 IMHO I would rather have fresh stock suspension with 18" and propery geometry than all the fancy suspension you could buy with bad or stock geometry. G/Tee I'd beat you around any B road! if that was the case lol so this guy could do a lot worse than just getting new stock J-spec springs and stock bilsteins? Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 I'll never forget the first very good geometry job i got done in Germany, I almost stopped the car to see if it had 2 sets of wheels on it!. Yes the difference was "that" big. I have found Supras to be an EXCELLENT handling car, when the geo is done. I fear no 2 or 4wd car in mine on the corners. People often ask for settings. Each multi changed setup needs its own, and even if you did give someone settings they'd probably get over excited while driving it, wreck it, and blame the geometry. I drove a stock vvti with 18"/RE050A and proper geometry, it handled superb. Handling and tyre choice is as important as any other factor. Link to comment Share on other sites More sharing options...
SatSport Posted November 14, 2007 Share Posted November 14, 2007 so this guy could do a lot worse than just getting new stock J-spec springs and stock bilsteins? He certainly could! Ernies not far away here, i just fitted yellow Bilstiens and VVTI springs from Chris Wilson last week and its now so so much better to drive. A lot of these jap kits are only for the `bowling green` roads in japan not the cart tracks we have here Link to comment Share on other sites More sharing options...
hoff Posted November 14, 2007 Share Posted November 14, 2007 Found a massive differance with mine after having the geo done a couple of days after fitting Bilstien shocks and a set of 19's. Link to comment Share on other sites More sharing options...
Chiefgroover Posted November 14, 2007 Share Posted November 14, 2007 He certainly could! Ernies not far away here, i just fitted yellow Bilstiens and VVTI springs from Chris Wilson last week and its now so so much better to drive. A lot of these jap kits are only for the `bowling green` roads in japan not the cart tracks we have here When are you coming for a demo Roy? Pampers required or a deposit on the new seats lol. Link to comment Share on other sites More sharing options...
KaoriFan Posted November 14, 2007 Share Posted November 14, 2007 I had TEIN Superstreets & EDFC fitted two weeks ago, and for the most part i find them perfect. It's only on the bad roads you notice the bumps, where they have a hard time coping, but even then my old vauxhall carlton felt them too, but not as bad as the Supra. I run on 19s and for the most part it's ok, but if i was doing it again maybe i would go for 18s. If i was closer to Interpro i would go there if i needed geometry work done next time. Thats where i got the SS and EDFC from. Have had a full geometry setup after the SS install and car does drive much nicer and feels like on rails and goes exactly where you want it to. ja ne Ian Link to comment Share on other sites More sharing options...
