Pioneer TS-SW1241D 12" Shallow mount Sub woofer in custom enclosure
Gamer
Pioneer TS-SW1241D 12" Shallow mount Sub woofer in custom enclosure. This set-up will sit right behind the rear seats and enables you to have full use of the rear boot. It sits right behind the rear seats and nestles in a perfect fit between them and the rear bulkhead. You still have full use of the rear boot cover and full access and use of the boot.
Details of the Sub woofer are as follows:
Pioneer TS SW1241D 30cm Shallow Type Subwoofer
A 30cm sub that is just 8.2cm deep - now you can boost your car audio with 1400 Watts of pure, solid bass of a superior sub without a complex installation.
Designed for enclose use, the TS-SW1241D combines the interlaced glass/carbon fibre reinforced IMPP (Injection-Moulded Polypropylene) double cone and our unique damper-less air suspension excursion control system.
A typical sub uses a damper to control the woofer’s cone excursion. Our air suspension system creates a sealed air space between the double cones, effectively replacing the damper and providing superior compliance linearity - regardless of the volume input - for reproducing exceptionally clear, low distortion bass sound.
Features
Interlaced Ultra Long Glass Fibre reinforced IMPP™ drive cone
3-layer fibre woven radial surround
Double cone reinforcement nodes
Damper-less, Air suspension excursion control system
Aluminium centre cap
Bottom-hold design aluminium die-cast chassis with fin shape design
Spring compression binding post terminal
4ohm voice coil
Specifications
Maximum Input Power: 1400Watt
Nominal Input Power: 350Watt
Frequency Response: 18-1000Hz
Sensitivity (1W/1m): 88dB
Woofer size: 30cm
Asking price is £145 not including postage as it is a heavy item. I can work out a price on postage if supplied with a postcode. Local collection is also available.
  • 2 weeks later...
  • 4 months later...
Price reduced to £100
Just to point this fact out again:
