Kenwood XXV-02A Anniversary Edition 4 ch amplifier
Gamer
Kenwood XXV-02A four channel 960W power amplifier main features:
Both single-channel and four-channel 25th anniversary amplifier models boast the highest sound quality thanks to carefully selected components in packages with a stylish deep-black finish. Keynotes are the special 25th anniversary capacitors, LAPT power transistors with superior high-frequency characteristics and LSI circuits, all mounted on glass epoxy PCBs. The result is the very finest in sound quality.
Amplifier features specially developed 25th anniversary super-filtering capacitors. Specially selected after extensive testing to provide the best matching, the electrolytic capacitors in this model feature drastically improved leak current characteristics to provide higher audio quality over a longer life and allow more natural sound reproduction that is ever-closer to the original
High quality glass-epoxy printed circuit board features larger circuit tracks than conventional designs to allow greater current handling capacity and assure stable power output. Improved circuit layout enhances frequency response characteristics and greater board rigidity serves to improve audio quality
High-speed output LAPT power transistors operate over an extremely wide frequency range, generating minimal distortion even at high currents
Max power output 960 watts
Blue top-mounted LED display can be set to display any of the following information:
Voltage: indicates the source voltage
Current: indicates the current consumption
Temperature: indicates the internal temperature
Fan: indicates the rotation speed of the cooling fan in 3 steps: Fast, Slow, or Off
Amp control system allows amplifier functions to be controlled by compatible head units
Computer controlled cooling fan
Detachable aluminium dress plate removes to reveal top control panel
Built-in parametric EQ control of Bass & Treble frequency / Gain control / Bass Q factor
Built-in low variable low-pass filter on B channel 50 - 200Hz (24dB/oct)
Built-in variable high pass filter on A/B channels 50 - 200Hz (12dB/oct)
Built-in infrasonic filter 15Hz (24dB/oct). Ultra-low frequencies that cannot be reproduced by a subwoofer do not become sound but become unnecessary oscillations, which affect sound by causing distortion. These frequencies also waste amplifier power and can cause damage to speakers. Setting the Infrasonic filter switch to 15Hz cuts signals below this frequency eliminating harmful distortion and protecting speakers
Gold-plated RCA line input / output terminals
Dimensions (WxHxD) : 446 x 61 x 260 mm
Asking price is: £150 including delivery
  • 2 weeks later...
  • 4 months later...
