can't start the engine - massive misfire?
xxcat
Can't start the engine anymore (even if it starts it massively misfires then and stops)..
Seems to be misfire issue. Diag codes: only code 14. Checked till now:
1) Crank sensor resistance: 1200ohm - ok (?)
2) Wiring - ok
3) Coil connectors - looks ok.
4) Ignitor connectors - ok
What more likely it could be? Ignitor, coils, maybe crank sensor (but no crank failure code?), what else? Is it possible to check something somehow? :)
The problem is - we have VERY few (2-3) mkiv supras here in Latvia and the only simple way to find the problem is to purchase new parts from Toyota (no swap for good unit option :) ).. But as always - not in stock and >2weeks for delivery. And it will be pretty expensive to test this way... New igniter + coils + sensors will cost very much :)
Please help.
