n/a
Guest ninelives
Why is it better?
using logic, toyota more than likely would have used there standard materials to make the filter, the same as you would find across the range
NOW TRD BEING RACE DEVELOPMENT would have made one with a higher air flow rate, as the car would be used in RACES and not normal daily drivin
Its called common sense
but you and your dad seem to not have any! but hows it go you can take the whore out of the.....
Ah right. So the NA was used in races was it? :confused:
After reading most of your posts, I would think quoting common sense would be the last thing you would want to do :rolleyes:
My Dad? And pray tell me oh wise one, where can I take the whore out of? :blink:
After reading the type of posts you and others like you put up, I seriously think there should be a control mechanism that allows access to where you can post. One area you should never ever be able to post is anywhere where you offer what could be considered "advice" on anything relating to the mechanics or performance of a Supra.
You have absolutely no idea whatsoever!
