gtylerroberts Posted November 11, 2007 Share Posted November 11, 2007 Ok - so I have a wide body kit, only subtle but it adds about 50mm each side of the car. Can anyone help me with where to start with getting wheels that will fill the arches. I have found most of the wheels I like aren't available to solve the problem. Any help you guys can give me will be greatly appreciated Thanks Quote Link to comment Share on other sites More sharing options...
hiten55 Posted November 11, 2007 Share Posted November 11, 2007 post pics Quote Link to comment Share on other sites More sharing options...
Nic Posted November 12, 2007 Share Posted November 12, 2007 Are you looking for a specific wheel model? I can supply wheels in the correct offset to fit if needed. See links to wheel manufacturers sites here http://mkivsupra.net/vbb/showthread.php?t=128500 Quote Link to comment Share on other sites More sharing options...
Inferno Posted November 12, 2007 Share Posted November 12, 2007 Ok - so I have a wide body kit, only subtle but it adds about 50mm each side of the car. Can anyone help me with where to start with getting wheels that will fill the arches. I have found most of the wheels I like aren't available to solve the problem. Any help you guys can give me will be greatly appreciated Thanks You just need to find wheels with a low offset which usually isn't a problem (especially for Volk/Rays wheels). Your only other options are a superwide wheel or use spacers. Quote Link to comment Share on other sites More sharing options...
Supranature Posted November 12, 2007 Share Posted November 12, 2007 See Matt H, hes got 12''x19'' on order-not cheap though. By adding width to your body styling lines you are adding considerable cost to wheels and tyres, as you will require sizes that are not common and probably require special ordering. Spacer utilisation is a no no though. Quote Link to comment Share on other sites More sharing options...
hoff Posted November 12, 2007 Share Posted November 12, 2007 If you contact one of the traders on here they maybe able to specify an offset which will fill the arches for you. Quote Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 12, 2007 Share Posted November 12, 2007 I specialise in widebody cars matey, can do Trafficstars, Works, Weds & more in appropriate sizes and fitments Drop me a PM with your requirements. Gaz. Quote Link to comment Share on other sites More sharing options...
