Brake Fluid help
xeno
My malfunction light comes on/off from time to time, and I noticed that the brake fluid is low.
On the reservoir cap it says to use DOT 3 fluid.
I have some DOT 4 fluid that says it's suitable to use as DOT 3 or 4 replacement, and that it is safe to mix with other fluids as long as they are not silicone based.
How the hell would I know if the stuff in there at present is silicone based? :search:
Don't tell me I'm gonna have to drain the brakes completely. :(
What's the worst that could happen?
The probabilty is that it's not silicone based (dot 5) unless some idiot has put some in, just put the dot 4 stuff in and you'll be okay.
There are basically two types of fluid:
1. Glycol based
2. Silicone based
Glycol based fluids can strip paintwork where as silicone based do not.
Try putting a little on the front wing and see if it's strips the paint.:D
Great. I'll try a bit on the paint of the missus' car, in an inconspicuous area.:D It's a pile of turd anyway.
