car engine run like a bus
China Man
My car battery was dead and the last time I drove it was 4 weeks ago. Parked on the road and the Clifford keep beep beep beep until all the juice in the battery is gone.
I have taken out the battery and charged it up with a battery conditioning charger. With the battery now connected back into the car it runs like a bus....
at idle the vibrations is like 2-3 second waves, hard to explain but it is like spinning a wheel which is uneven. If I rev the engine up after 1k revs the vibration is gone.
I tried to reverse gear to move a few meter and OMG the engine is like almost stalling if I don't press on the accelerator.
I did a search on here and a few post said that I need to drive it for 20mins to let the ECU learn the fueling and ignitions again, is that true?
Benson
It is probably down to the ECU being reset so it will hunt about a bit more than usual on idle at first, it may also be compounding a dirty idle control valve, but the ECU does not take twenty mins to re learn, it simply just resets the idle control, leave it running for a few mins and turn on the air con and lights.
