Guest mattwilliams Posted November 9, 2007 Share Posted November 9, 2007 is it possible to use the driveshafts and prop shaft from an auto mkiv into a manual mkiv? Quote Link to comment Share on other sites More sharing options...
TLicense Posted November 9, 2007 Share Posted November 9, 2007 Yes, if you use the auto diff as well. No if you're going to use a manual diff. Quote Link to comment Share on other sites More sharing options...
Guest mattwilliams Posted November 9, 2007 Share Posted November 9, 2007 no its a manual car so the diff is a manual one. so does this mean the prop and drivshafts wont fit if they are auto ones? Quote Link to comment Share on other sites More sharing options...
Guest mattwilliams Posted November 10, 2007 Share Posted November 10, 2007 anyone? Quote Link to comment Share on other sites More sharing options...
TLicense Posted November 10, 2007 Share Posted November 10, 2007 Yes it means they won't fit. Well not properly. It depends on how much of a bodge job you want to do. Check out this for more info:- http://www.mkiv.com/techarticles/auto_to_6spd_swap/differential/index.html Quote Link to comment Share on other sites More sharing options...
