Hunting-Power loss-No starting...Bugger!
Lbm
Gentlemen your opinions please!
I have a J-Spec 93' TT 6speed manual.
She's now in a garage hopefully getting fixed, but I'd like your ideas on the probable causes of her recent illness
2 weeks ago: Idleing between 400-900 revs
2-3 days later: Loss of power when doing 40-70 mph (like driving
in to a headwind, as one other member described in their situation)
2-3 days later: Trying to start...nearly...then...No!
In the middle of this I could smell fuel.
My mechanic tells me the engine managment light is showing no error codes...(is this normal, or even ok?)
What do you think it sounds like?
Thanks
Rob
Hi Rob,
I'm not sure how far you've got on with this but we've just fixed a car which come in with exactly the same symptoms.
What happened was the bolt fastening the crank pulley was loose, which had caused the cambelt to rub against to the crank sensor reading pulley which has distorted the pickup/signal that the crank sensor gets.
Get him to strip it down and have a look, on this car the belt had worn through the lower timing case so it was easier to see once down there. You'll need a few parts to fix it (new pulleys, lower cover, cambelt, seal, key) upto £400 at retail plus labour.
Regards,
Gaz.
Personally I'd tell them nothing, as, like telling the doctor what you have, it's bound to wind them up. If you don't trust them take it elsewhere. I once knew a guy who took his car to a garage, left it 2 hours, went on the `Net to ask his friends opinions, and rang them to TELL them his head gasket was gone. Seeing their arse they fitted a new head gasket and rang him to pay and collect. It still overheated. They then told him it needed a new thermostat. He learnt an expensive lesson... ;) They probably still chuckle about closet experts. Once you start telling THEM what's up, and how to fix it, YOU carry the can if it still doesn't work, leave them to it and THEY carry the can :)
Thanks Gav
I'll be speaking to the garage tomorrow. Good of you to remember this..
Cheers
Rob
Edit, just in from CW...
Personally I'd tell them nothing, as, like telling the doctor what you have, it's bound to wind them up. If you don't trust them take it elsewhere. I once knew a guy who took his car to a garage, left it 2 hours, went on the `Net to ask his friends opinions, and rang them to TELL them his head gasket was gone. Seeing their arse they fitted a new head gasket and rang him to pay and collect. It still overheated. They then told him it needed a new thermostat. He learnt an expensive lesson... They probably still chuckle about closet experts. Once you start telling THEM what's up, and how to fix it, YOU carry the can if it still doesn't work, leave them to it and THEY carry the can
__________________
Good point Chris, however, Dave, the mechanic has looked after my cars for 15 years, so I feel it's in safe hands. I can't resist asking a few questions on here, as there are some very knowledgeable members. Once again good to know people looking out for each other on this site.
Thanks
Rob.
