miko_supra Posted December 23, 2007 Author Share Posted December 23, 2007 day 11 part 2 ok just did all the small little odd bits... (still waiting on a few little bits, if your wondering why i havnt already done some other stuff) -connected the ecu's up (you need a 2jz-gte ecu to replace the 2jz-ge one and a throttle control ecu which is about half the size of the main ecu) these both sit in the passenger foot well and are joined up to the engine loom that got fed down. -next fit the new tt air box - then fit the inter cooler piping -this diagram will explain better than any pictures http://xs122.xs.to/xs122/07510/104intercoolerpiping.JPG -then connect up the steering rack connector -theres a round one and a square one on the TT, im yet to find out what the round one is for, but the square one is what goes into the steering rack http://xs322.xs.to/xs322/07515/whatarethese.JPG -fit the throttle cable. it connects up onto the part nearest passenger side. the other is for cruise control if you have that http://xs122.xs.to/xs122/07510/105throttlecable.JPG -then fit the fan (if you had taken it off) -then fit the radiator and upper and lower radiator hoses. -fill the radiator with coolant -then fit the exhaust heat shields -refit this bracket http://xs221.xs.to/xs221/07465/040driveshaft.JPG -refit exhaust system (2nd cat, cat back) Link to comment Share on other sites More sharing options...
p111ddy Posted December 23, 2007 Share Posted December 23, 2007 Cracking write up fella & looking good Link to comment Share on other sites More sharing options...
miko_supra Posted December 26, 2007 Author Share Posted December 26, 2007 day 12 -fitted the inter cooler -fitted the inlet pipe from the air box to the manifold http://xs322.xs.to/xs322/07523/107inletpipe.JPG -fitted the new tt power steering reservoir and piping. http://xs322.xs.to/xs322/07523/106powersteeringreservoir.JPG -now the engine can be safely test run... -ensure all the electrical connectors are connected properly (check and double check!) as you don't to stress yourself out trying to find why the engine wont start. -check your coolant and fuel lines! Dont be surprised it if doesn't all go to plan first time around... -i turned the key in mine, then discovered the battery was flat, so i hooked it up to my other cars battery and turned the key. the starter motor was running fine, but the engine didnt want to start. i looked under the car to discover a large puddle of petrol underneath the petrol filter. a washer was missing from the bolt that held down the fuel line to the engine DOH! so i soon found this and fitted that. -turned the key again and the engine fired up just fine! -although once looking around i noticed a horrible chattering noise coming from the front of the engine. i soon discovered that the power steering system needed bleeding as there was allot of bubbles in the reservoir. to bleed the system... -jack the front end of the car off the ground, start the engine and move the steering wheel full lock left to full lock right (i did this about 10-15 times) this should bleed the system no problem. -ok with that sorted i took the car for a little test drive (no bumper fitted so couldn't use the main roads...just up the block and back was all i did) -drive it carefully, check the clutch and gears all engage properly and TEST YOUR BRAKES! then bring it back and keep it running. then do a leak check (i hadn't fitted the floor pan yet for this reason) Link to comment Share on other sites More sharing options...
miko_supra Posted December 26, 2007 Author Share Posted December 26, 2007 day 13 ok now just to add the final touches. -fitted the active spoiler and front bumper -fitted the engine pan -fitted the new tt tack (the whole cluster including speedo, rev counter, petrol and temp gauge.) i had an auto tack which meant it had all the gear select lights on the rev counter. theres no point trying to swap over the manual face as you have to take the whole thing apart and you can run the risk of messing up the calibration. for the moment i just took all the bulbs out the back and stuck a piece of black tape over them, until i get some new nice white dials to go over the top. -this might help http://www.mkiv.com/techarticles/Indiglo_gauge/index.html -then fitted the gear surround and gear knob -secured the ecu's, refitted the foot well cover and carpet. -then i took the car out for a short run. the 1st turbo should kick in just under 3000rpm and the second comes in at around 4500rpm. you'll feel and hear them, so if you don't notice both stages then something ain't right! -the car ran well, and it was better than i had predicted, this engine really is a magnificent piece of engineering by toyota. :):) It was abit damp so i couldn't give it too much. You also need to go easy on the clutch if its new and run it in properly. http://xs322.xs.to/xs322/07523/108finished.JPG http://xs122.xs.to/xs122/07523/109finished.JPG thanks jezz at silverstone garage for supplying me with the engine and parts and thanks all those on here that provided me with some excellent advise Link to comment Share on other sites More sharing options...
Jezz Posted December 26, 2007 Share Posted December 26, 2007 Excellent, well done mate. Link to comment Share on other sites More sharing options...
redsupraman82 Posted December 26, 2007 Share Posted December 26, 2007 Clap,Clap Clap.....that was awsome mate! been watching this project in great detail! Good Work! Link to comment Share on other sites More sharing options...
AndyT Posted December 26, 2007 Share Posted December 26, 2007 Brilliant job. Well done Miko..Buy you a beer at a meet in 08. Link to comment Share on other sites More sharing options...
ukApache Posted December 26, 2007 Share Posted December 26, 2007 :thumbs: Link to comment Share on other sites More sharing options...
Guest InnocentSupra Posted December 27, 2007 Share Posted December 27, 2007 Simply amazing. I take a bow. Link to comment Share on other sites More sharing options...
Missile Posted December 27, 2007 Share Posted December 27, 2007 Very very well done. How much would you charge to do this to someone else's car. Ha Ha Link to comment Share on other sites More sharing options...
Masenko Posted December 27, 2007 Share Posted December 27, 2007 Great that you're finally done! I'm hoping to do this in March... Link to comment Share on other sites More sharing options...
DamanC Posted December 27, 2007 Share Posted December 27, 2007 Bravo Link to comment Share on other sites More sharing options...
Sparky Posted December 31, 2007 Share Posted December 31, 2007 Im really impressed. Well done! Link to comment Share on other sites More sharing options...
DannyB Posted December 31, 2007 Share Posted December 31, 2007 Top work mate well done! Link to comment Share on other sites More sharing options...
supra-lover Posted December 31, 2007 Share Posted December 31, 2007 pukka read,, very well done that man Link to comment Share on other sites More sharing options...
supramemole Posted December 31, 2007 Share Posted December 31, 2007 hey all...been reading this thread and its awsome. Im in the US and have a RHD supra na/auto am thinking about doing this swap. I have a question...was that a true supra motor or an aristo motor??? if aristo motor is there any insight on the wiring... that seems to be my biggest thing right now... Just me Chris Link to comment Share on other sites More sharing options...
miko_supra Posted December 31, 2007 Author Share Posted December 31, 2007 hey all...been reading this thread and its awsome. Im in the US and have a RHD supra na/auto am thinking about doing this swap. I have a question...was that a true supra motor or an aristo motor??? if aristo motor is there any insight on the wiring... that seems to be my biggest thing right now... Just me Chris yeah its a supra engine, i think the aristo engine has a different oil sump on it and this wont fit in the supra with that on so it needs modifying or replacing so i've heard. i don't know about the wiring Link to comment Share on other sites More sharing options...
supramemole Posted December 31, 2007 Share Posted December 31, 2007 yea the sump needs to be changed to front like the supras.. the wiring is the biggest question i have...no one in the world seems to have a aristo ecu pinout..lol... at least none i can find...and i have been looking for three days straight!!!! Just me Chris Link to comment Share on other sites More sharing options...
miko_supra Posted December 31, 2007 Author Share Posted December 31, 2007 yea the sump needs to be changed to front like the supras.. the wiring is the biggest question i have...no one in the world seems to have a aristo ecu pinout..lol... at least none i can find...and i have been looking for three days straight!!!! Just me Chris have you tried looking on http://www.clubna-t.com? theres quite a bit of info on there Link to comment Share on other sites More sharing options...
RobSheffield Posted December 31, 2007 Share Posted December 31, 2007 Nice job Link to comment Share on other sites More sharing options...
standardsupra20 Posted January 2, 2008 Share Posted January 2, 2008 Bloody good work mate, don't think I'll be doing it myself thou. Link to comment Share on other sites More sharing options...
miko_supra Posted January 2, 2008 Author Share Posted January 2, 2008 fuse box connector -the upper black connector, which goes into the fuse box needs swapping with the one from the n/a engine to the one from the tt engine. -this is because they are different. i have drawn a lovely diagram on paint to try and explain this as the photo i took came out all blurry. but basically 3 of the wires from the tt loom go into the old n/a connector (only 3 terminals) and you are left with a blue one. which on mine was wrapped up in insulation tape and then tucked into the loom. the picture shows the clip side of the connector facing you and the wire colours are [black + red] [yellow] [black (also thicker than the others)] http://xs323.xs.to/xs323/08013/111fuseboxconnector.JPG Link to comment Share on other sites More sharing options...
jim_supra Posted January 2, 2008 Share Posted January 2, 2008 Good pic, makes it easier to understand. It might be worth noting though that there are 2 red and black wires on the TT side of the loom, these will need joining together and connecting to the one wire that goes in to the connector off the NA loom. Link to comment Share on other sites More sharing options...
miko_supra Posted January 2, 2008 Author Share Posted January 2, 2008 Good pic, makes it easier to understand. It might be worth noting though that there are 2 red and black wires on the TT side of the loom, these will need joining together and connecting to the one wire that goes in to the connector off the NA loom. thankyou that man! Link to comment Share on other sites More sharing options...
gaz1 Posted January 2, 2008 Share Posted January 2, 2008 i take my hat off to that man, well done;) Link to comment Share on other sites More sharing options...
