Whitesupraboy2 Posted December 18, 2004 Share Posted December 18, 2004 ive been trying to get my calipers nuts off for over a hour and half now!! (tryin to replace pads) and not one has loosened ive got it soaked in wd40 i got a spanner on it and using a mallet whacking one way whacking it back trying to loosen it off. also tried shock treatment...just beating it! im stuck the nuts arent budging!! what else can i do? to top it off ive lost a centre cap to a wheel this morning as well! Link to comment Share on other sites More sharing options...
LeeT Posted December 18, 2004 Share Posted December 18, 2004 you're going to have to get a 17mm hex head socket and a long breaker bar Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 18, 2004 Author Share Posted December 18, 2004 leet...u got it right...neighbour to the rescue!! just finished! Link to comment Share on other sites More sharing options...
merckx Posted December 18, 2004 Share Posted December 18, 2004 I know it's a bit late now. I had the same problem on my 3.5 tonne van, the bolts were extremely tight, this was because of the locking compound on the thread. I warmed it up a little with the blowtorch - much easier! Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 18, 2004 Share Posted December 18, 2004 They can't be THAT tight, they are only piddling little things, I can shear a bolt that size with a standard 1/2 drive ratchet handle. They undo the conventional way, anti clockwise looking at the bolt head. If you are struggling with those don't bother trying to do a cambelt change Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 18, 2004 Author Share Posted December 18, 2004 cheeky Bugger basically it was coz i was using a normal spanner! put a circle head one on it, tap of mallet...straight undun Im not joking when i say with the normal spanner i was hanging on it with body off floor! Link to comment Share on other sites More sharing options...
merckx Posted December 18, 2004 Share Posted December 18, 2004 They undo the conventional way, anti clockwise looking at the bolt head. :D :D Tight is when you break the end of a socket extension which I did recently. Link to comment Share on other sites More sharing options...
