200mph on A1
JamesC
  • Replies 83
Guest Grinder
I was there on the day this was done and it was definately 200 mph. There were 3 of them in the car and it was no bs. No one brags about doing 200 kph (125 mph), that skyline was one of the most heavily modded in the country and the engine blew the following year I seem to remember.
I know of this guy... its a genuine 650hp skyline r34 rebuilt will all nismo parts... think he spent arround 35k plus on it..... had allot of problems with it though
You won't get anywhere near 650BHP using just Nismo parts.
Even if you went to the Omori factory the most you could drive away with is 450PS with the R1 package.
http://www.nismo.co.jp/shop/shop/omori/engine/r1/index.html
Next time he should try a run without the 180kph factory limiter fitted.
Guest Grinder
Here's the spec list from when he put it up for sale:
Early R32 reinforced and seasoned race block
HKS Forged 87mm pistons
HKS piston rings
HKS Forged H-section conrods
HKS Strengthened bolts
Lightened, balanced, treated crank
Nismo race bearings
Nismo shells and main seals
Tomei Sump baffle kit
Trust sump kit
Trust modified oil pickup
Nismo Oil pump
Nismo Water pump
HKS 1.6mm Steel Headgasket
HKS Steel inlet and exhaust gaskets
HKS Main gasket set
New nissan valves, buckets, uprated stem seals etc
HKS 264 Cams, springs and vernier pullies
Matched and flowed Plenum, throttle bodies, inlet tract and exhaust manifold
Ported head and valves
HKS Iridium spark plugs
Extra earthing kit
SARD 720cc injectors
Greddy fuel rail with aeroquip lines
Nismo fuel pressure regulator
HKS fuel pump
Apexi Racing suction kit
Apexi 80mm induction hard pipes
80mm Airflow meters
HKS GT race intercooler
HKS GT2530 needle roller bearing turbos
HKS Uprated actuators
HKS Stainless turbo elbows
HKS Matched length downpipes
HKS Cat bypass
HKS Hiper Muffler exhaust
HKS Evc V Electronic boost controller
Apexi PowerFC ecu
HKS GD Pro Triple plate clutch
HKS Modified fork
HKS Lightened and balanced flywheel
Trust Dowmax uprated lowering springs
Guest Grinder
HKS piston rings
Nismo race bearings
Trust sump kit
Nismo Oil pump
Nismo Water pump
HKS Main gasket set
Extra earthing kit
HKS fuel pump
80mm Airflow meters
HKS Cat bypass
Apexi PowerFC ecu
HKS Modified fork
One thing to note, whenever I've rewatched any videos of myself, the camera doesn't half take the feeling of speed away, go down a round @ 150 leptons & record it, when you play it back on a computer screen it sure won't look like 150.
