pete.w Posted November 6, 2007 Share Posted November 6, 2007 need some advice on me heater problem, stopped blowing hot air its luke warm only, also the temp control switch lights dont light up but the speed and other lights do . could this be just a fuse or is it the heater ecu thingy . thanks Quote Link to comment Share on other sites More sharing options...
smithn05 Posted November 6, 2007 Share Posted November 6, 2007 Sounds like block matrix to me, loads of threads on here for it. If its only just started doing it, its possible you might be able to clean it through with some of the drain cleaning acid stuff you get a B&Q but be careful its nasty stuff. As for the lights on the temp control, Im assuming you mean the backlighting at night, as the temp control doesnt have any leds. Thats a simple replacement bulb issue (although Toyota want to charge a fortune for the lil blighters), there is a thread on here somewhere with a link to a web site that sells them although I cant find the it, maybe someone else knows it. Quote Link to comment Share on other sites More sharing options...
pete.w Posted November 6, 2007 Author Share Posted November 6, 2007 thanks for the reply will have another look through past posts, ye i did meen the back lights just thaught its worth mentioning as it did work but packed up at the same time as the hot air flow . Quote Link to comment Share on other sites More sharing options...
carl0s Posted November 6, 2007 Share Posted November 6, 2007 If the heater controls are not working then it's unlikely to be a blocked matrix. First thing I would do is get the heater controls out, take it apart and re-melt the solder. It's easy enough to do, not much chance of anything going wrong. Quote Link to comment Share on other sites More sharing options...
Fifty Posted November 6, 2007 Share Posted November 6, 2007 :d try bleeding air out of your coolant - assuming you eliminate the possible electrical problem work safely warm up car with rad cap off rev gently and carefully and you should see air bubble out - fill her up and see if it now works worked for me and no problems since Rich Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2015 Share Posted March 7, 2015 (edited) Check this in passenger foot well Not sure how i posted in this thread lol Edited March 7, 2015 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Fitz Posted March 7, 2015 Share Posted March 7, 2015 not sure how i posted in this thread lol Quote Link to comment Share on other sites More sharing options...
