supraguye Posted November 6, 2007 Share Posted November 6, 2007 Guys, I need to put a restrictor ring on, but because I'm out in the caribbean, it looks like i'm gonna have to make it. A few questions: - What material can I use? - What size should it be? - Where does it go? .... between what sections of the exhaust? THanks Link to comment Share on other sites More sharing options...
jamesmark Posted November 6, 2007 Share Posted November 6, 2007 I need to put a restrictor ring on, but because I'm out in the caribbean, it looks like i'm gonna have to make it. Rubbish, unless where you stay does not have a post man. Contact a trader on here I am sure they can get a quote for to post, it'snot as if a restrictor ring is heavy. Traders include Chris Wilson, Envy, Whifbitz. As said all found in the traders section. - What material can I use? Don't know - What size should it be? Varies it is only approximate iirc the hole should be appx 52mm for 1.2bar - Where does it go? Between the first and second cat THanks Link to comment Share on other sites More sharing options...
supraguye Posted November 6, 2007 Author Share Posted November 6, 2007 Thanks mate .... would actually prefer to buy it, will PM a few of the traders. Thanks Dudley Link to comment Share on other sites More sharing options...
Ewen Posted November 6, 2007 Share Posted November 6, 2007 Rubbish, unless where you stay does not have a post man. Contact a trader on here I am sure they can get a quote for to post, it'snot as if a restrictor ring is heavy. Traders include Chris Wilson, Envy, Whifbitz. As said all found in the traders section. - What material can I use? Don't know - What size should it be? Varies it is only approximate iirc the hole should be appx 52mm for 1.2bar - Where does it go? Between the first and second cat THanks :dOooo, get her Link to comment Share on other sites More sharing options...
