jaw Posted November 5, 2007 Share Posted November 5, 2007 I'm fully paid up now but on the downside, I have a problem! I recently bought a TT as shown on other thread, from someone on this forum, it was all well, but I'm having problems now! I need to sell on as I have to move out now, and will be buying an aerotop n/a in replacement, but today, the supra erupted in steam :'( Opened the bonnet, and a quick view showed steam pouring from the back of the block, I couldnt tell where from, and temperature sky rocketed, happened when stationary. I turned off immediatley, and moved it to a parking space. All coolant had gone - I had some in the car spare though so topped up.. I then went to drive home, and the temp rose again. Not as much steam as I wasnt driving for as long. There has been no other indication prior to this, no white engine smoke other than condensation on start up, no mayo in the oil from what I can see, no leaks any one have any ideas? It's my typical luck, had it since august, need to sell to move out and this happens!!! If it's a head gasket gone, I'll have to take it off the road till I have the money which I really want to avoid many thanks Quote Link to comment Share on other sites More sharing options...
michael Posted November 5, 2007 Share Posted November 5, 2007 How many pieces is your rad cap in? Quote Link to comment Share on other sites More sharing options...
jaw Posted November 5, 2007 Author Share Posted November 5, 2007 two? one at the front and then another behind the fan further up the engine. first is a plastic flip off one with 'coolant' written on it, on what I thought was the expansion tank, but it's connected to the second which is a metal twist off cap Quote Link to comment Share on other sites More sharing options...
Pete Posted November 5, 2007 Share Posted November 5, 2007 Unfortunately even if you have a bad rad cap which can cause this, if it was steaming like you said and lost ALL coolant, you may be in for some very bad news. The twist off cap. They need replacing quite regularly. Quote Link to comment Share on other sites More sharing options...
jaw Posted November 5, 2007 Author Share Posted November 5, 2007 the thing is, there was no steam coming from either cap so even if it's the cause, I don't think it was what I was seeing? I hadn't checked coolant for well over a week though, so I have no idea how quickly this loss was.. It's so frustrating as I've had it for so little time and the only time it's started to play up is now Quote Link to comment Share on other sites More sharing options...
Pete Posted November 5, 2007 Share Posted November 5, 2007 The rad cap fails causing loss of pressure in the system. The coolant doesn't get round the engine properly causing hot spots, left in this state the water will bubble away. Not sure if you'd get steam from the rad cap - I would've thought so? Quote Link to comment Share on other sites More sharing options...
jaw Posted November 5, 2007 Author Share Posted November 5, 2007 I would've when it failled? that said, I may well have, there was a lot of steam, however when I tried again it seemed to be seaping out of the rear of the engine, It looked like a pipe had split but now not so sure. Temperature rises quickly, I need to get it home today - only a 2 minute drive, will this be ok?? it wont hit the red in these two minutes, so I can have a better look. Quote Link to comment Share on other sites More sharing options...
jaw Posted November 5, 2007 Author Share Posted November 5, 2007 also if anyone has an idea what would need doing i'd be grateful - I'm guessing I'm in for a hefty bill though In 2months it's needed a starter motor and whatever's wrong now, and I'm about to MOT it, all so I can then sell it! at least my concience will be happy knowing i've fixed any major issues before I sell! Quote Link to comment Share on other sites More sharing options...
TrickTT Posted November 5, 2007 Share Posted November 5, 2007 Before you panic too much, there is a rubber pipe (for the heater matrix) that drops down the back of the engine above the bellhousing. It's hard too see in situ, but check that before you panic about the h/g as they are prone to splitting. Quote Link to comment Share on other sites More sharing options...
jaw Posted November 5, 2007 Author Share Posted November 5, 2007 Thanks trick, am glad you said that, as I had the feeling it came from a pipe, so fingers crossed - I'll check tonight if it's light enough. do you know where the pipe runs from and to? cheers Quote Link to comment Share on other sites More sharing options...
MRX Posted November 5, 2007 Share Posted November 5, 2007 Core plug leaking maybe...? Quote Link to comment Share on other sites More sharing options...
TrickTT Posted November 5, 2007 Share Posted November 5, 2007 Thanks trick, am glad you said that, as I had the feeling it came from a pipe, so fingers crossed - I'll check tonight if it's light enough. do you know where the pipe runs from and to? cheers It comes from the heater matrix, and drops down the back of the engine behind the exhaust cam. It connects up to the water return hard pipe that runs under the turbos. Its quite hard to see and an even bigger pita to remove, but you should be able to see if its wet. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted November 5, 2007 Share Posted November 5, 2007 It comes from the heater matrix, and drops down the back of the engine behind the exhaust cam. It connects up to the water return hard pipe that runs under the turbos. Its quite hard to see and an even bigger pita to remove, but you should be able to see if its wet. I would say that to, had mine go a little while ago. Quote Link to comment Share on other sites More sharing options...
jaw Posted November 5, 2007 Author Share Posted November 5, 2007 It's a little too dark so unless I get some good light, I'll have to assess in the morning - out of interest, what did it cost you guys to sort the problem? is it diyable enough? Cheers:) edit: I think I've located the hose that split - it's hissing away but if I give it a squeze this hissing stops. I suppose I hadn't noticed it when it had started before so perhaps it got up to a higher temp hence all the steam. Can't see how to get to the split, but it appears to be closer to the top.There shouldnt be any concequencial damage if this is the case as once up to heat the engine was shut down, and it occurred from cold so oil temp wouldnt have been phenomenal... Quote Link to comment Share on other sites More sharing options...
TrickTT Posted November 6, 2007 Share Posted November 6, 2007 Hose costs about £25 from toyota, plus some new coolant. Its certainly a diy job, just a bit fiddly to get at. Quote Link to comment Share on other sites More sharing options...
Konrad Posted November 6, 2007 Share Posted November 6, 2007 Hose costs about £25 from toyota, plus some new coolant. Its certainly a diy job, just a bit fiddly to get at. But Rich, for you even headgasket change is DIY job Quote Link to comment Share on other sites More sharing options...
