MichaelG Posted December 17, 2004 Share Posted December 17, 2004 Its about that time, and i am considering putting my MKIV N/A 1994 J-Spec into Toyota to get the Timing Belt done, but they are notorious for overpricing here. Can someone give me a rough estimate of what i should be looking to pay to have the timing belt supplied and fitted by them please ? Also is the standard belt fine enough, or is there an aftermarket one thats stronger for just the same price ? Cheers Michael Link to comment Share on other sites More sharing options...
Digsy Posted December 17, 2004 Share Posted December 17, 2004 £215.93 at my local Toyota dealer. Link to comment Share on other sites More sharing options...
weinelm Posted December 18, 2004 Share Posted December 18, 2004 I payed £193 at my local Toyota garage. I was expecting it to be more! Timing belt £28.83 Labour £135.50 Consumables £3.50 Plus the dreaded VAT £28.76 Worth having done on a Jspec for peace of mind, cos they don't seem to have much in the way of service history. Link to comment Share on other sites More sharing options...
weinelm Posted December 18, 2004 Share Posted December 18, 2004 ...Which reminds me... Before I had my belt changed there was a little sticker on the camcover that said something in Japanese about the milage of the timing belt change. Does anyone know if this means:- a) Mileage that the belt WAS changed at, or b) Mileage that the belt is DUE for change. Since I've had my belt done I have a new sticker that says in English option a). But wonder is the Jap label is different? I want to know cos it would probably help be verify whether my ODO milage is genuine or not! Link to comment Share on other sites More sharing options...
Nic Posted December 18, 2004 Share Posted December 18, 2004 Power Enterprise make uprated timing belts for the Supra, I have one fitted on my car, not sure how the cost compares to standard belt. http://www.power-enterprise.co.jp/ Link to comment Share on other sites More sharing options...
Barnstormer Posted December 18, 2004 Share Posted December 18, 2004 weinelm if you post a picture of the sticker I will translate it for you. My Japanese is rusty but still OK. ATB Link to comment Share on other sites More sharing options...
paul mac Posted December 18, 2004 Share Posted December 18, 2004 having done the belt myself, if you can get a price of £200 like the above guys i would say that is a fair price, its not a hard job just alot of messing particularly if the bottom pulley nut wont come off, see if you can get a fixed price Link to comment Share on other sites More sharing options...
weinelm Posted December 18, 2004 Share Posted December 18, 2004 Thanks I'll see if a can get the old sticker off, trouble is it's under the new one! Link to comment Share on other sites More sharing options...
absz Posted December 19, 2004 Share Posted December 19, 2004 i changed a couple and both times the crank pully has been so tight to undo . Link to comment Share on other sites More sharing options...
weinelm Posted December 20, 2004 Share Posted December 20, 2004 if you post a picture of the sticker I will translate it for you. My Japanese is rusty but still OK. ATB Please see attached. Sorry it's a bit grainy - I couldn't separate it from the new one stuck on top, so I had to scan it from the back and flip it! Link to comment Share on other sites More sharing options...
Barnstormer Posted December 20, 2004 Share Posted December 20, 2004 was fairly straighforward to translate. Basically is says: Timing Belt Replacement (Maintenance Record) Was Replaced: 21 April 2001 Mileage: 99396 km So that was when it was done, not when it needed to be done. The dates are in Japanese format which is a bit different. The 13 4 21 means 13th year of Emperor Showa's reign, 4 month, 21st day. Currently it is Year 16 in Japan by their calendar. Hope this helps. ATB Link to comment Share on other sites More sharing options...
weinelm Posted December 21, 2004 Share Posted December 21, 2004 That's great thank you! That all seems to stack up. Looks like I might have replaced my belt a year or so early... but theres no harm in that! Link to comment Share on other sites More sharing options...
mr keef Posted December 22, 2004 Share Posted December 22, 2004 when should it be changed? miles wise? Link to comment Share on other sites More sharing options...
rob wild Posted December 22, 2004 Share Posted December 22, 2004 I had mine inspected by a local Toyota dealer and they said it could do with changing, the car has done 43K, but they were charging 260 pounds to do it! So i took it to a local garage that deals with imports and they replaced all the belts for £160 which i was really please with. As far as changing the belts etc i was told to have a look at the maintenace schedule below: http://www.mkiv.com/manual/manualtt/maintenance_schedule/a.jpg I don't know where people follow it or not. Link to comment Share on other sites More sharing options...
