which ecu
gaz1
  • Replies 57
If you're after a link, speak to Ryan before ordering ;)
From what I've read here over the years Motec is seems to be one of the better ones available, however factoring in the mapper makes the Link much more favourable for us in the South...
The LinkG3 plus is definatly on par with the Motec m600 IMO and it was aimed to compete with it.
I have just finished mapping one on a supra today and the owner was baffled by how much it can.
As a run down on the supra this is how i normally set it up but other options are available.
- Sequetial injection
- Direct Spark ( no need for a DLI :tongue:)
- Built in 3D boost controlled with MAC solenoid so can sell current controller.
- Boost controllable by either Gear setup or Volume knob
on a switch
- Switched outputs to control anything you like based on parameters in engine, i.e water injection come on at XXXXrpm and XX boost pressure when switch is activated. Also Can fit shiftlights, IC spray and many other items
- All factory settings like aircon idle up etc are kept
- All VSV's round engine are still controlled
- Ign and fuel trims setup for different temps
- Dual maps at switch for normal unleaded fuel or race fuel
- Launch control on switch
- Antilag on switch
And many more features but its a sunday and im tired :D
