Epic Posted November 4, 2007 Share Posted November 4, 2007 got abit of a rattle when i rev the car, pull away etc, around 1800rpm n 2200rpm ish... sounds like a tinny rattle from the back of the engine bay, maybe under... any idears? im thinking a heat sheld or sumthing Link to comment Share on other sites More sharing options...
Epic Posted November 4, 2007 Author Share Posted November 4, 2007 any idears on where and how i can get to the heat sheld to have a look Link to comment Share on other sites More sharing options...
smithn05 Posted November 6, 2007 Share Posted November 6, 2007 There are loads of heat shields around the front part of the exhaust, so not easy to tell you much ... you need to get under there and find out which one it is!!! Mine does it at 1200rpm and I will be buggered if I can find out which one it is!!! Link to comment Share on other sites More sharing options...
juanchan Posted November 6, 2007 Share Posted November 6, 2007 The heat shield right under my turbos has corroded around one bolt and it rattles quite a lot when you close the throttle. It looks pretty impossible to really do anything about it without removing copious amounts of turbos and associated "stuff", so I'm leaving it for now Link to comment Share on other sites More sharing options...
bodilx6 Posted November 7, 2007 Share Posted November 7, 2007 Could it be the tranny? The 6-speed is know for making all kinds of funny sounds. Mine also rattles when setting off Link to comment Share on other sites More sharing options...
