HID kit info required
M4RK RZ
Hi chaps -
So im just about to get a HID kit form ebay still deciding on seller tho.
going for 6000K 9005 HB3
now..
I want to do all the nights (not fussed about fogs tho) Side lights x4 and full beam half beam.
Do I have to buy the extra bulbs - do I run these thro the balasts? and if so do you splice in or is there a certain balast to get with extra outs?
Or do I go LED white side bulbs?
Suggestions on kits please
Mark, you will need 2 x HID kits (bulbs and ballasts) for the dip beam and main beam. So in total you'll need 4 ballasts and 4 bulbs. If you have J-spec headlights you need 2 x 9005/HB3 kits, they will be a straight fit without any modifying.
For the side lights I would use LED's.
I can supply HID kits for £115 including postage
How much would J-spec headlights 2 x 9005/HB3 kits be of you Nic?
Yes they are normal style, my personal opinion is that it pointless for full beams to be HID unless you really do a lot of night driving, you will not be able to flash people because of the delay in them warming up.
Do the fogs, it requires you to mod it a little, there is a thread.
  • 2 weeks later...
