Really quick question - OIL ????????
Jamesy
Hi mate. Got this from the experts at Opie Oils.
2JZ-GTE Engine Oil (TT Engine on a MKIV (UK or JDM))
Stock = 10w30 Semi Synthetic
I recommend Fully Synthetic 10w40/50
Dry Capacity 6.5L's
Change capacity 5-6L's (Have 6L's ready)
Regular Driving - BPU or Less
5w40 - Silkolene Pro S, Castrol RS, Motul 300V Power
5w50 - Valvoline VR1 SynPower, AGIP PC5w-50
Regular Driving - BPU to Big Power
10w40 - Motul 300V Chrono, Royal Purple Racing 41
10w50 - Silkolene Pro S
10w60 - Castrol RS (NB Untested)
Track Oil
15w50 - Silkolene Pro R, Motul 300V
I'd recommend the 10w50 Silkolene as it's Ester based unless I was using the car only for short journey's then i'd use the Valvoline.
NB: Mobil1 0wxx has been known to get passed the piston rings and cause excessive oil consumption. I would recommened ALL 0wXX oils are avoided. 5W is the lowest I would use.
See here for details on how to change your oil.
Interval = 3-9,000miles depending on use/power levels
Have fun. :)
what about the gearbox oil.
quantity and which oil please
Manual 6-speed V160/161 Gearbox
Stock = Toyota V160 oil (PART No. 08885-01306)
Capacity 1.8l's when dry
Toyota V160 Oil (comes in 1L cans - require 2 cans)
Esso Dextron D21065
I recommened you stick with stock
Interval = 2 Years / 30,000miles depending on use/power levels
Automatic 4-speed A340E
Capacity = 8.2L's (But you can only really change what's in the sump of it and that is ~2L's)
Stock = Toyota Type-IV - 2L's for a quick change. Have 10L's ready for a full flush.
