Going to fit Goodrich brake lines at the weekend
markrzs
na dude no need to run the motor
just make sure all the air is out
a good way to check for air is once all the brakes are blead get in the car and pump the brake hard and fast!! then hold it down and if the pedal stays solid youre ok but if it drops any there is still air in the system
alex
alex
Spot on cheers Alex :thumbs:
thin mate :) She's all done now although the pedal seems a bit spongy ? is there air in the system ?
Nothing like a deep pan is there :D
Yeh theres probably still air in the system, try bleeding it again... have you fitted new discs or pads? If so it might be that they need to 'bed in' a bit
