markrzs Posted November 1, 2007 Share Posted November 1, 2007 I'm going to follow this guide http://www.mkiv.com/techarticles/trd_ss_brake_lines/index.html But does anone else have any tips ? Cheers Mark Quote Link to comment Share on other sites More sharing options...
Steviekid Posted November 1, 2007 Share Posted November 1, 2007 But does anone else have any tips ? When you're taking the old ones off, either buy a proper brake spanner or get a normal spanner and hit it sharpy with a hammer. DO NOT try and slowly undo them with lots of force as they will round off. You then have to hacksaw bits off and swear a lot. Quote Link to comment Share on other sites More sharing options...
bmx1lew Posted November 1, 2007 Share Posted November 1, 2007 getting mine done tonight... i was going to do them myself but every one i spoke to said its harder to see air bubbles with braided lines, the origonal lines are black... people put me off with horror storey's, i thought it would be easy to do ? Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 1, 2007 Author Share Posted November 1, 2007 When you're taking the old ones off, either buy a proper brake spanner or get a normal spanner and hit it sharpy with a hammer. DO NOT try and slowly undo them with lots of force as they will round off. You then have to hacksaw bits off and swear a lot. That seems to be the main problem, well it dose'nt put me off so i'll still have a go, thanks lads Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted November 1, 2007 Share Posted November 1, 2007 make sure when bleeding the brakes that you don't overtighten the bleed nipple as they are very fragile. You'll end up with a big crack and brake fluid pissing all over your hands, then you'll have to buy a new caliper, fit it and rebleed the whole system again meaning your car will be off road for approx 2/3 days. Can you tell I'm talking from experience? Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 1, 2007 Author Share Posted November 1, 2007 Has it happened to you then Luke by any chance ? Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted November 1, 2007 Share Posted November 1, 2007 Oh its funny you should ask Mark yes, just last month I put braided lines all around... ended up buying a second hand caliper from a scrapyard for £50 You have been warned! lol Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 1, 2007 Author Share Posted November 1, 2007 cheers bud. lol Quote Link to comment Share on other sites More sharing options...
Dave F Posted November 2, 2007 Share Posted November 2, 2007 Did mine in a few hours mate no problems. Definately! use a brake spanner. A few people have had trouble with the pipe end being too flared after removing the old hose and a small file may be needed, I was lucky all mine were fine... Good luck matey Quote Link to comment Share on other sites More sharing options...
ultra_supra Posted November 2, 2007 Share Posted November 2, 2007 think i'm gonna get phoenix to do mine in the new year - i'm usually alright with these kinda things but don't wanna run the risk with brakes....just incase!!!! Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 2, 2007 Author Share Posted November 2, 2007 Did mine in a few hours mate no problems. Definately! use a brake spanner. A few people have had trouble with the pipe end being too flared after removing the old hose and a small file may be needed, I was lucky all mine were fine... Good luck matey Cheers Dave, i'll keep a look out for flared threads, not sure if i've got a brake spanner so perhaps a pair of mole grips might do the job ? Mark Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 3, 2007 Author Share Posted November 3, 2007 bit of a daft question but....... if I take off the old brakes hose's to replace with the Goodrich hose's won't all the fluid pour out ? And i'd definatly need to bleed each of the brakes too ? Cheers Mark Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 3, 2007 Author Share Posted November 3, 2007 anyone ? Quote Link to comment Share on other sites More sharing options...
ECK Posted November 3, 2007 Share Posted November 3, 2007 once you have taken off the first brake line jam down the brake pedal with a bit wood or rod that way the fluid wont run out oh and remember to change the fluid too DOT 5.1 is the fluid you want alex Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 3, 2007 Author Share Posted November 3, 2007 cheers Alex, i've got 2ltrs of Motul 5.1 Quote Link to comment Share on other sites More sharing options...
GazzaGSi Posted November 3, 2007 Share Posted November 3, 2007 Is anyone using this kit? http://cgi.ebay.co.uk/GOODRIDGE-BRAKE-LINE-KIT-TOYOTA-SUPRA-JZA80_W0QQitemZ290174606376QQihZ019QQcategoryZ23013QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Im having some UK brakes fitted soon so may as well upgrade the lines too. Anyone had any experience with this? Cheers Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 3, 2007 Author Share Posted November 3, 2007 I think thats the place I bought mine from. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted November 3, 2007 Share Posted November 3, 2007 Is anyone using this kit? http://cgi.ebay.co.uk/GOODRIDGE-BRAKE-LINE-KIT-TOYOTA-SUPRA-JZA80_W0QQitemZ290174606376QQihZ019QQcategoryZ23013QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Im having some UK brakes fitted soon so may as well upgrade the lines too. Anyone had any experience with this? Cheers Thats the same bloke I bought mine from Quote Link to comment Share on other sites More sharing options...
GazzaGSi Posted November 3, 2007 Share Posted November 3, 2007 Cool cheers guys Quote Link to comment Share on other sites More sharing options...
Dave F Posted November 3, 2007 Share Posted November 3, 2007 You done em yet then??? Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 4, 2007 Author Share Posted November 4, 2007 I've fitted 3 hoses, going to do the other in a minute and then bleed the system! When I started to get the first flare nut off I thought, " What have I started ? " it would not budge ! but then got my trusty old mole grips out Mark Quote Link to comment Share on other sites More sharing options...
Bob Posted November 4, 2007 Share Posted November 4, 2007 A bit late, but Halfrauds do very good quality brake pipe spanners for a couple of quid Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 4, 2007 Author Share Posted November 4, 2007 A bit late, but Halfrauds do very good quality brake pipe spanners for a couple of quid Now you tell me ! No matter mate, just as easy with a pair of mole grips Cheers. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted November 4, 2007 Share Posted November 4, 2007 Is it finished yet? Quote Link to comment Share on other sites More sharing options...
markrzs Posted November 4, 2007 Author Share Posted November 4, 2007 Just about to bleed now, do you have to have the engine running to bleed the brakes ? Quote Link to comment Share on other sites More sharing options...
