jazz1 Posted October 31, 2007 Share Posted October 31, 2007 ok last week i changed my fan shroud cover and have a slight worry i may of missed something. When i turn the ignition on the two small fans start spinning and dont turn off, they stay on even when the car is running etc. Should these only come on when required or should they stay on all the time? first picture is for the two connectors for the two small fans but i cant seem to figure out what the grey connector is, would that maybe be a sensor connector for the two small fans? maybe i might of forgot to connect it but i couldnt see anything? Quote Link to comment Share on other sites More sharing options...
carl0s Posted October 31, 2007 Share Posted October 31, 2007 Must be dude. My fans don't startup right away, I'm (almost) sure if it. How much did the correct shroud cost in the end? Long time for delivery? Quote Link to comment Share on other sites More sharing options...
jazz1 Posted October 31, 2007 Author Share Posted October 31, 2007 Must be dude. My fans don't startup right away, I'm (almost) sure if it. How much did the correct shroud cost in the end? Long time for delivery? 70 pounds Quote Link to comment Share on other sites More sharing options...
jazz1 Posted October 31, 2007 Author Share Posted October 31, 2007 bump any1 Quote Link to comment Share on other sites More sharing options...
SUPRASUZUKI Posted October 31, 2007 Share Posted October 31, 2007 There's a sensor/switch in the bottom of the rad. If you don't connnect the plug to the sensor the fans run. Quote Link to comment Share on other sites More sharing options...
hadyn Posted October 31, 2007 Share Posted October 31, 2007 cant see there being any problems if the fans run all the time? Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted October 31, 2007 Share Posted October 31, 2007 As SupraSuzuki says they come on all the time if the switch in the bottom of the Rad is not connected up correctly. Quote Link to comment Share on other sites More sharing options...
jazz1 Posted October 31, 2007 Author Share Posted October 31, 2007 wicked il have to check that i though something sounded odd lol cheers guys:) Quote Link to comment Share on other sites More sharing options...
