Supra ECU Register
Wez
  • Replies 310
Posted Images
1993 6spd
Setup:
Stock 3L motor (59k miles)
HKS Fcon V-pro
HKS Knock Amp/ wideband
HKS 264 cams
BL67mm .68 a/r Turbo Kit
3" downpipe/ Blitz Nurspec Exhaust
Precision 800cc injectors, Dual Denso Pumps, etc...
Apexi AVC-R Boost Controller
And a bunch of other bolt on parts that won't effect the numbers... HKS DLI, ATI Crank dampener etc...
Power
527whp/441wtq - 19psi 91 octane
651whp/550wtq - 28psi 111 octane
NOTE- I had a bad exhaust leak between my turbo and manifold which caused it to spool slower. 1/2 the gasket was actually missing! So it didnt' spool as fast as it could have.
Race gas 111 octane (28psi)
1993 6spd
Setup:
HKS Fcon V-pro
HKS 264 cams
Power
Who mapped it and how do you rate them out of 10?
  • 1 month later...
AEM Ecu
6 speed manual
PHR stage 1
mapped by Paul Whiffin
10/10
not been on the dyno yet ... running 1.6 bar, so approx 560 hp (will get it dyno'd after winter)
Luc :)
Added, once you have a dyno plot I can add a power figure :thumbs:
Wez as I have not managed to blow the engine yet, you might want to add this to the list.
I don't know if cams should be added to the list as my 280 make a huge difference up top. My RPM and compression also make it an unfair comparison with stock engines.
AEM
Six speed
GT74DBB(mods) work done by Ben(Obiwan)Supraforums
Martin/MBAuto
10/10 so far to 0.75bar
Dyno pending
Edited by Terminator (see edit history)
  • 2 weeks later...
  • 2 weeks later...
