Supra ECU Register
Wez
Tenttu, HKS F-Con V Pro, Manual, Holset HX50 MFS, AMWorks, 602fwhp 560ft/lb, Stock JDM engine, 1.16bar and with V-power.
I will post the dyno plot in few days, thanks.
This is in fifth gear:
As u can see the turbo kicks in quite hard.. Anyways i think that this turbo is the one to have if u want middle sized 67mm turbo :)
Edited by Tenttu (see edit history)
  • 3 weeks later...
  • Replies 310
Posted Images
One more to proudly add to the register if possible?
ECU: AEM v1
Trans: 6 Speed (V160)
Turbo: Bullseye Power S362 Billet Batmowheel
Cams: Whifbitz 264/264
Mapped By: Ryan.G
Rating: 10/10
Result: 624.7hp/520ftlbs
Notes: 1.5 bar
Wez,
can you update mine please.
ECU : AEM
Trans : 6 Speed
Turbo : BW 91-79 0.91 twin scroll
Mapped By : Ryan
Rating : 10/10
Notes : 1.8 BAR; HKS 264 cams; GReddy intake
Power and torque : 767bhp (650.8 rwhp) & 632 ftlbs (535.9 rwtq) at 1.8 bar
Thanks ;)
Can you add my latest trip to the dyno at Scooby Clinic Chesterfield today...
Engine: Standard 3ltr
ECU: LinkG3
Trans: 6 speed TT
Turbo: Billet 4040
Cams: Standard
Boost: 1.5bar
Mapped By: Ryan.G (the man)
Rating: 10/10
Result: 576.1hp/550ftlb?
Comment; More to come when 5bar MAP is purchased and installed :eyebrows:
It's a shame that so many in the list are missing their dyno plots (mainly the manual ones). I know power as a raw figure isn't that useful and dynos not consistent but seeing the torque and power curves along with the choice of turbo, cams, ecu & boost used to achieve it really helps give you an idea of what combination works well when choosing your own setup for your particular goals. Without the plots, the results don't tell you nearly as much :(
C'mon everyone! Get your dyno plots uploaded!! ;)
  • 1 month later...
  • 1 month later...
  • 2 months later...
413BHP 450 Ftlb
Turbo: stock ceramic Jspecs
Cams: Stock
Mapped By: Ryan.G
Rating: 10/10
Notes: 1.2 bar boost, 550cc injectors, full decat + catback exhaust, Greddy irridium plugs, Trust FMIC, K&N Air intake, Turbos running in TTC
ECU: Greddy Emanage Blue
:thumbs:
  • 1 month later...
Good numbers Si :thumbs: What boost pressure were you running?
1.6 bar. Switched from all the UK MAF to MAP, breather for EGR and Paul's new FMIC.
The exhaust housing is undivided, I'm going to when I can afford to, get a divided housing on this and change nothing else, then take it back to SRR and see what that does for the setup as I'm currently not using the manifold to it's true potential.
Reminds me, I even have to ask Paul what wastegate spring pressure is, as I have no idea currently :) I haven't even driven the car yet.
  • 1 month later...
Update for you...
T67DBB
syvecs s6gp
1.5 bar max
Engine Specifications: built July 2005
Assembly fully balanced.
BoostLogic Lightened/Dampened Crank Pulley
Eagle H Beam Steel Rods
ARP 625 Custom Age Rod Bolts
ARP Mains Studs
Reground/Balance Crank
Clevite Bearings
New Modified Oil Pump
New Modified Front Main Seal
Custom Breather System
Sard Oil Filter
BoostLogic Billet Tensioner Bracket
Power Enterprise Timing Belt
HKS Valcon Inlet Cam
HKS 264 ex Cam
Supra NL Uprated Valve Springs
ARP Head Studs
Blitz LM Front Mounted Intercooler
Blitz 1.3 KG/CM2 Radiator Cap
Custom Aluminium Header Tank
Carbon FMIC Cover
Fluidyne Radiator
GReddy Aluminium Top Hose
Aux power steering cooler
Aux oil cooler
Turbocharger & Induction:
BL T67DBB .81 ar dual ball bearing and water cooled
Anaught Cast manifold.
Coolingmist variable water/meth injection
HKS 50mm Wastegate
HKS Racing BOV
Exhaust:
BL 4" Downpipe/Midpipe
BL 4" stainless steel Exhaust
TNX
  • 4 months later...
