Wez Posted September 3, 2008 Author Share Posted September 3, 2008 Can I be added please? Mapped by Ryan 10/10 , Boost Logic (Precision) T67 DBB, 264 inlet and exhaust cams, AEM management, 644.2 Bhp and 520 ft lb Attached dyno plot. Done. Link to comment Share on other sites More sharing options...
cwtt Posted September 10, 2008 Share Posted September 10, 2008 1993 6spd Setup: Stock 3L motor (59k miles) HKS Fcon V-pro HKS Knock Amp/ wideband HKS 264 cams BL67mm .68 a/r Turbo Kit 3" downpipe/ Blitz Nurspec Exhaust Precision 800cc injectors, Dual Denso Pumps, etc... Apexi AVC-R Boost Controller And a bunch of other bolt on parts that won't effect the numbers... HKS DLI, ATI Crank dampener etc... Power 527whp/441wtq - 19psi 91 octane 651whp/550wtq - 28psi 111 octane NOTE- I had a bad exhaust leak between my turbo and manifold which caused it to spool slower. 1/2 the gasket was actually missing! So it didnt' spool as fast as it could have. Race gas 111 octane (28psi) Link to comment Share on other sites More sharing options...
Wez Posted September 10, 2008 Author Share Posted September 10, 2008 1993 6spd Setup: Stock 3L motor (59k miles) HKS Fcon V-pro HKS Knock Amp/ wideband HKS 264 cams BL67mm .68 a/r Turbo Kit 3" downpipe/ Blitz Nurspec Exhaust Precision 800cc injectors, Dual Denso Pumps, etc... Apexi AVC-R Boost Controller And a bunch of other bolt on parts that won't effect the numbers... HKS DLI, ATI Crank dampener etc... Power 527whp/441wtq - 19psi 91 octane 651whp/550wtq - 28psi 111 octane NOTE- I had a bad exhaust leak between my turbo and manifold which caused it to spool slower. 1/2 the gasket was actually missing! So it didnt' spool as fast as it could have. Race gas 111 octane (28psi) Who mapped it and how do you rate them out of 10? Link to comment Share on other sites More sharing options...
cwtt Posted September 10, 2008 Share Posted September 10, 2008 Who mapped it and how do you rate them out of 10? Justin Nenni tuned it. He was 11/10 haha. 10/10 for sure. He is amazing. Link to comment Share on other sites More sharing options...
supradibbs Posted October 15, 2008 Share Posted October 15, 2008 Mine 598 447 ftlbs No where near the max yet:d Link to comment Share on other sites More sharing options...
gledo1970 Posted October 15, 2008 Share Posted October 15, 2008 Name Gledo1970 Ecu Solaris 6 speed Manual GT4094R DBB hks 264 cams Mapped by Ryan G Rating 10/10 Result 631.3BHP & 500 ft lbs Link to comment Share on other sites More sharing options...
Wez Posted October 16, 2008 Author Share Posted October 16, 2008 Name Gledo1970 Ecu Solaris 6 speed Manual GT4094R DBB hks 264 cams Mapped by Ryan G Rating 10/10 Result 631.3BHP & 500 ft lbs Added Link to comment Share on other sites More sharing options...
Wez Posted October 16, 2008 Author Share Posted October 16, 2008 Justin Nenni tuned it. He was 11/10 haha. 10/10 for sure. He is amazing. Added Link to comment Share on other sites More sharing options...
Wez Posted October 16, 2008 Author Share Posted October 16, 2008 Mine 598 447 ftlbs No where near the max yet:d Have you got a dyno print? Link to comment Share on other sites More sharing options...
Luxluc Posted October 16, 2008 Share Posted October 16, 2008 Name : Luxluc AEM Ecu 6 speed manual PHR stage 1 mapped by Paul Whiffin 10/10 not been on the dyno yet ... running 1.6 bar, so approx 560 hp (will get it dyno'd after winter) Luc Link to comment Share on other sites More sharing options...
Wez Posted October 16, 2008 Author Share Posted October 16, 2008 Name : Luxluc AEM Ecu 6 speed manual PHR stage 1 mapped by Paul Whiffin 10/10 not been on the dyno yet ... running 1.6 bar, so approx 560 hp (will get it dyno'd after winter) Luc Added, once you have a dyno plot I can add a power figure Link to comment Share on other sites More sharing options...
Steve Posted October 16, 2008 Share Posted October 16, 2008 Wez add me aswell. T67Dbb 6 Speed Apexi Power FC Mapped by Ryan.G Power at 552bhp at the minute. Need to get mapping finished 10/10 so far. Link to comment Share on other sites More sharing options...
Wez Posted October 16, 2008 Author Share Posted October 16, 2008 Wez add me aswell. T67Dbb 6 Speed Apexi Power FC Mapped by Ryan.G Power at 552bhp at the minute. Need to get mapping finished 10/10 so far. I have added you, do you have a link to a power graph? Link to comment Share on other sites More sharing options...
Steve Posted October 16, 2008 Share Posted October 16, 2008 I have added you, do you have a link to a power graph? http://www.putfile.com/pic/8356448 Link to comment Share on other sites More sharing options...
Terminator Posted October 16, 2008 Share Posted October 16, 2008 (edited) Wez as I have not managed to blow the engine yet, you might want to add this to the list. I don't know if cams should be added to the list as my 280 make a huge difference up top. My RPM and compression also make it an unfair comparison with stock engines. AEM Six speed GT74DBB(mods) work done by Ben(Obiwan)Supraforums Martin/MBAuto 10/10 so far to 0.75bar Dyno pending Edited October 16, 2008 by Terminator (see edit history) Link to comment Share on other sites More sharing options...
Wez Posted October 16, 2008 Author Share Posted October 16, 2008 Updated with Smarty dyno and added terms Link to comment Share on other sites More sharing options...
supradibbs Posted October 29, 2008 Share Posted October 29, 2008 here you go http://www.mkivsupra.net/vbb/showthread.php?t=165720&page=3 Link to comment Share on other sites More sharing options...
cwtt Posted October 29, 2008 Share Posted October 29, 2008 Wez- FYI you have me listed with the wrong turbo. On the chart it should be "BL 67." (Not DBB) You have me listed as BL 61 DBB which is incorrect. Link to comment Share on other sites More sharing options...
Wez Posted October 29, 2008 Author Share Posted October 29, 2008 Wez- FYI you have me listed with the wrong turbo. On the chart it should be "BL 67." (Not DBB) You have me listed as BL 61 DBB which is incorrect. Fixed Link to comment Share on other sites More sharing options...
Pig Posted October 30, 2008 Share Posted October 30, 2008 Hi Wez, I would like to update mine please. AEM T61 Manual Ryan G 10/10 (now that its been mapped by Ryan) 575 bhp 500ftlbs Link to comment Share on other sites More sharing options...
botachi Posted November 11, 2008 Share Posted November 11, 2008 (edited) Using GReddy E-Manage Ultimate using stock twins although did TTC mod mapped by my partner Carlito 8/10 so far but not yet totally done. Its a 6-speed USDM TT mkiv Edited November 13, 2008 by botachi (see edit history) Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2008 Author Share Posted November 11, 2008 here you go http://www.mkivsupra.net/vbb/showthread.php?t=165720&page=3 Updated. Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2008 Author Share Posted November 11, 2008 Hi Wez, I would like to update mine please. AEM T61 Manual Ryan G 10/10 (now that its been mapped by Ryan) 575 bhp 500ftlbs Do you have a dyno sheet so I can add the power figure? Link to comment Share on other sites More sharing options...
Wez Posted November 11, 2008 Author Share Posted November 11, 2008 Using GReddy E-Manage Ultimate using stock twins although did TTC mod mapped by my partner Carlito 8/10 so far but not yet totally done Is the car manual or auto? botachi E-Manage Ultimate ????? Stock TT in TTC Carlito 8/10 waiting Link to comment Share on other sites More sharing options...
botachi Posted November 13, 2008 Share Posted November 13, 2008 Wez, edited again sorry i keep missing out on the fields Link to comment Share on other sites More sharing options...
